Author Topic: An unsafe swap space has been detected. (how to fix, no info working in the net)  (Read 1235 times)
Offline clix
Hello! When I tried installing Peppermint 8, and encrypt the files, it gave me this error message:
https://i.imgur.com/u7IJw21.jpg
After this it takes me to a partition dialog box but I do not know what to do there. I did some searches and they work different. Something about the home root. I guess I could create a swapoff folder here and it will be resolved?
I tried running the swapoff command - sudo swapoff -all - and it didn't work
I followed step by step 3 or 4 extensive walkthroughs in other known forums and it didn't work either, I guess their issue is different than mine.
I would really like to install Peppermint 8, as I am new to Linux, and I have runned out of resources, I find myself in a dead street because I can't fix it with the info I find in the internet.
Any help is appreciated!  8)
« Last Edit: December 29, 2017, 02:48:58 pm by clix »
Looks like you've chosen full disk encryption, but kept an unencrypted swap partition .. you need to use:
sudo ecryptfs-setup-swap
to encrypt your swap partition
https://blog.sleeplessbeastie.eu/2012/05/23/ubuntu-how-to-encrypt-swap-partition/
http://manpages.ubuntu.com/manpages/trusty/man1/ecryptfs-setup-swap.1.html
Unless you have a requirement for full disk encryption I'd personally reinstall without it .. sure it's secure, but iit can be a PITA if anything ever goes wrong.
« Last Edit: December 29, 2017, 03:26:59 pm by PCNetSpec »
