Author Topic: What is gain from uprgading to PEP8?  (Read 1136 times)
Offline cihan.kizilarmut
« on: December 26, 2017, 09:55:47 pm »
Is there any advantage on uprgading to 8 over staying with 7?
Sent from my SM-J727P using Tapatalk
Re: What is gain from uprgading to PEP8?
« Reply #1 on: December 27, 2017, 01:03:58 am »
Hi cihan.kizilarmut,
Welcome to the forums   :)
That is a difficult one to answer and will be different for each user.
First you need to read each of the following News posts and decide is there any feature mentioned that you need to resolve a particular problem or that you think would be cool to have.
https://peppermintos.com/2016/11/peppermint-7-respin-released/ Peppermint 7 Respin
https://peppermintos.com/2017/05/peppermint-8-released/ Peppermint 8
https://peppermintos.com/2017/12/peppermint-8-respin-released/ Peppermint 8 Respin
Each new version brought new things to the table and you will have to weight up do you really need any of those new things.
For me the biggest question is - is everything running perfectly OK on the P7 install - if the answer is yes then stay put. Both versions are running off the 16.04 LTS Base and will be supported until 2021.
If the answer is no - what is the problem ?
have you sought a solution on the Forum that has not been resolved?
have you read something somewhere that suggests a new kernel might be the answer?
There are simply too many factors to answer this with a simple Yes/No type statement.
Other members of the Forum will come along with their opinions/ideas/suggestions and that is one of the strengths of this community, a diversity of answers to help you decide whether to upgrade or not.
« Last Edit: December 27, 2017, 03:31:54 am by zebedeeboss »
Linux User #565092
Offline Ly
« Reply #2 on: December 27, 2017, 03:13:10 am »
as ZebedeeBoss said, you should ask the question "do i really need to upgrade ?".  I upgraded from 7 to 7 resping then to 8 but i think i could just have stayed to Pmint 7 as it was running without any problem, the forum is here if you ever need help.
« Reply #3 on: December 27, 2017, 08:38:13 am »
As others already mentioned, this is up to your needs and wishes. I've installed quite a few linux machines in the past months, so I just don't feel like doing it once more. I'm on PM7 Respin and will stick to it until the next LTS base, i.e April 2018... probably I'll jump from my current 7 respin to the future 9 respin. Who knows?
But, hey check your needs and take it from there
« Reply #4 on: December 27, 2017, 06:46:14 pm »
+1  <--that :)
(sorry, couldn't resist)
« Reply #5 on: December 27, 2017, 07:00:39 pm »
Bwahahahahaha !   :D
+2
Offline grafiksinc
« Reply #6 on: December 28, 2017, 05:02:18 am »
I stayed on P7 does all I need really  ;).......... I am with Pin just waiting for the next LTS base to come out ... will probably stay where I am until P9.
« Reply #7 on: December 28, 2017, 11:01:37 am »
I only have Peppermint 8 on one computer, my main desktop.  My laptop and my Steam Machine are both running 7.  There's definitely nothing wrong with that, there's still a few years of support left for both 7 and 8.  :)
The PoorGuy
  • Guest
« Reply #8 on: January 03, 2018, 03:31:25 pm »
« Last Edit: August 27, 2018, 10:25:33 pm by The PoorGuy »
