Author Topic: (SOLVED)Touch-pad Issues  (Read 2460 times)
Offline mikew2017
« on: December 26, 2017, 01:37:34 pm »
Is there a way to disable the touch-pad when typing through peppermints settings, cause this HP laptop of mine is almost unusable if I don't. I have found a program called Touchpad-Indicator but it must load up at start up.
« Last Edit: December 26, 2017, 04:10:31 pm by mikew2017 »
Re: Touch-pad Issues
« Reply #1 on: December 26, 2017, 02:04:28 pm »
If you go to Menu, Preferences, Peppermint Control Centre, under the Keyboard & Pointer tab - there are touchpad options.
Take a look there.
Offline mikew2017
« Reply #2 on: December 26, 2017, 03:57:42 pm »
There isn't any option for disabling the touch-pad,  anybody got a good tutorial on creating a configuration file for synaptics driver?
« Reply #3 on: December 26, 2017, 03:59:17 pm »
See here for a tutorial on killing the touchpad temporarily whilst typing
https://forum.peppermintos.com/index.php/topic,1239.0.html
Offline mikew2017
« Reply #4 on: December 26, 2017, 04:11:40 pm »
Thank you that worked perfectly thank you!
Re: (SOLVED)Touch-pad Issues
« Reply #5 on: December 26, 2017, 04:18:02 pm »
You're most welcome :)
Offline Ran
  • Peppermint version(s): OS 9
« Reply #6 on: November 13, 2018, 04:30:01 am »
Thank You too... needed it... as I only use a mouse... ;)
« Reply #7 on: November 13, 2018, 06:34:42 am »
