Author Topic: "Shader model 3 must be supported" (SOLVED)  (Read 2672 times)
Re: "Shader model 3 must be supported"
« Reply #15 on: December 20, 2017, 06:14:56 pm »
What's the output from
xrandr
chadwix
  • Guest
« Reply #16 on: December 20, 2017, 07:15:09 pm »
$ xrandr
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 16384 x 16384
DVI-I-0 disconnected primary (normal left inverted right x axis y axis)
DVI-I-1 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 620mm x 340mm
   3840x2160     60.00 +  59.94    50.00    30.00    29.97    25.00    23.98
   2560x1440     59.95
   2048x1280     60.00
   1920x2160     59.99
   1920x1080     60.00*   59.94    50.00    23.97    60.00    50.04
   1600x1200     60.00
   1280x1024     75.02    60.02
   1280x800      59.81
   1280x720      59.94    50.00
   1152x864      75.00
   1024x768      75.03    60.00
   800x600       75.00    60.32
   720x576       50.00
   720x480       59.94
   640x480       75.00    59.94    59.93
DP-0 disconnected (normal left inverted right x axis y axis)
DVI-D-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
Thanks again, learning all sorts of new commands
« Reply #17 on: December 20, 2017, 07:31:25 pm »
Do you know what the native resolution of your monitor is ?
I'm wondering because as both the icons AND text are larger than expected if this is simply an incorrectly set resolution issue.
If it were JUST large text I'd think it was a DPI issue, but not with both.
« Reply #18 on: December 20, 2017, 07:45:38 pm »
Try running
sudo xed /etc/X11/xorg.conf
and adding the line
	Option         "DPI" "96 x 96"
to the "Device" section, so it now reads
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 384.90  (buildmeister@swio-display-x86-rhel47-05)  Tue Sep 19 18:13:03 PDT 2017
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0"
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Unknown"
    HorizSync       28.0 - 33.0
    VertRefresh     43.0 - 72.0
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
SAVE the file, and log off/on.
Remember, you may have to change the font size back to default.
chadwix
  • Guest
« Reply #19 on: December 20, 2017, 07:46:12 pm »
That fixed it perfectly, been using peppermint for over a year and this comp always had this problem.
Thanks a ton, you fixed my driver and font :)
Any idea why that setting would change or be deleted?
« Last Edit: December 20, 2017, 07:54:54 pm by chadwix »
Re: "Shader model 3 must be supported" (SOLVED)
« Reply #20 on: December 20, 2017, 08:23:34 pm »
None whatsoever .. I've always had to add that with nvidia drivers or I end up with small text (but only in certain places like the menu) .. go figure :-\
« Last Edit: December 20, 2017, 08:25:22 pm by PCNetSpec »
