Author Topic: Tutorial for upgrading Peppermint 8 --> Peppermint 8 Respin now available.  (Read 4008 times)
Offline tetricky
  • Peppermint version(s): 8, 9
Re: Tutorial for upgrading Peppermint 8 --> Peppermint 8 Respin now available.
« Reply #1 on: December 17, 2017, 07:03:11 am »
Thank you very much for that.  I ran on a 64bit laptop installation, and all went exactly as it should.
Will there be a similar upgrade path to future versions, or is it likely to be a re-flash (as it were)?
« Reply #2 on: December 17, 2017, 07:09:41 am »
At this point any answer to that would be speculation.
We're not specifically looking to design in the ability to upgrade PM8 --> PM9 (that would rule out major changes), but if it's possible for us to do or to provide a manual tutorial that's reliable and risk free, we will.
No promises though....
Offline stevesveryown
  • Peppermint Fan
    • stevesveryown
« Reply #3 on: February 19, 2018, 05:52:05 pm »
Question, will my personal files and installed applications be affected by the upgrade?  I've never tried anything like this and don't want to reinstall everything after it finishes.
« Reply #4 on: February 20, 2018, 01:07:19 am »
Hi stevesveryown,
No problem. However, having said that, it is never wrong to back up important files!!  ;)
See this tutorial to see how to obtain even more safety for your personal files.
« Reply #5 on: February 20, 2018, 02:14:07 am »
No, user files and installed applications should be unaffected, but a backup never hurts.
  • Peppermint Fan
    • stevesveryown
« Reply #6 on: February 20, 2018, 03:55:58 pm »
Thank you both for the reply.
  • Peppermint Fan
    • stevesveryown
« Reply #7 on: February 25, 2018, 09:27:03 pm »
Update: I did it. Wow, it was so easy! The only issue is I can't get an image to appear on the log in screen. Everything else went fine. Peppermint rocks!
  • Peppermint Fan
    • stevesveryown
« Reply #10 on: February 27, 2018, 04:26:47 am »
And as always, you're most welcome Steve :)
