Author Topic: Problem installing peppermint8 to new laptop [SOLVED]  (Read 1513 times)
Offline adamunderwood
  • Still learning
  • Peppermint version(s): 6,8, and 9
« on: December 13, 2017, 01:24:37 am »
I picked up a new msi  gs63060 laptop.  It was a spur of the moment purchase that I let the damn salesman talk me into.  I am really starting to think I made a mistake.  I have been having problems trying to install Peppermint.  I figured since this is newer than anything I have ever owned I should go with Peppermint 8.   When trying to install the computer boots up to the grub menu.  I choose to install peppermint and it brings up the Peppermint logo and the progress bar goes good to maybe about 20% or so complete and then freezes.  I have redownloaded and redid the flashdrive with unetbootin several times.  The last time I even used windows and rufus on the new computer and still had the same result.  I then figured I would try my Peppermint 6 usb from previous installations.  All was going well.  It made it all the way into the installation screens but would not see that it was connected to the internet so I did not go any further.  I have it hooked up with an ethernet connection directly to the modem.  I know all of the connections and signal were good though because when I had the computer running in windows everything was working .   I have seen questions in other peoples posts on here about different things like uefi vs legacy which I did come across in the bios menu when setting up the boot order but I honestly do not know anything about that.  Before this one the newest computer I had played with was originally windows vista, however old that is.  Sorry I dont have much more information to give.
« Last Edit: December 14, 2017, 09:10:24 am by adamunderwood »
Re: Problem installing peppermint8 to new laptop
« Reply #1 on: December 13, 2017, 01:49:07 am »
Hi adamunderwood,
What happens if you use the try before you install option ?  (or however it's worded - just not straight to installation)
How far does it get using that option?
If you do get to a desktop - can you post the terminal output from the following command
Linux User #565092
  • Still learning
« Reply #2 on: December 13, 2017, 02:03:13 am »
Hi Zeb, when I choose to try Peppermint instead of install, it has the same result.  Brings up the logo, underneath that it says Starting Up..., and the progress bar goes maybe 3/8 of an inch and then freezes.  I never can get to a terminal to try that command.
Also, I just tried what PCNetSpec suggested regarding the quiet splash in this thread
https://forum.peppermintos.com/index.php/topic,6076.15.html
It proceeds through a bunch of processes and then goes to a blank screen with the following:
Peppermint Eight peppermint tty1
peppermint  login:
It does not accept any login and password I try.
« Last Edit: December 13, 2017, 02:16:37 am by adamunderwood »
« Reply #3 on: December 13, 2017, 02:30:20 am »
OK
Trying what PCNetSpec said ignore the rootdelay and add nomodeset instead so it now ends with
nomodeset --
See if that gets you any further
Linux User #565092
  • Still learning
« Reply #4 on: December 13, 2017, 02:42:56 am »
ok, that got it to load all the way to a liveUSB session (I am actually posting this from the new computer).
terminal output from your inxi -Fz command is
System:    Host: peppermint Kernel: 4.10.0-40-generic x86_64 (64 bit) Desktop: N/A
           Distro: Peppermint Eight
Machine:   Mobo: Micro-Star model: MS-16K4 v: REV:1.0
           Bios: American Megatrends v: E16K4IMS.10E date: 08/16/2017
CPU:       Quad core Intel Core i7-7700HQ (-HT-MCP-) cache: 6144 KB
           clock speeds: max: 3800 MHz 1: 899 MHz 2: 899 MHz 3: 899 MHz 4: 2130 MHz
           5: 2430 MHz 6: 2180 MHz 7: 899 MHz 8: 899 MHz
Graphics:  Card-1: Intel Device 591b
           Card-2: NVIDIA Device 1c8d
           Display Server: X.Org 1.19.3 drivers: fbdev (unloaded: vesa)
           Resolution: 800x600@75.00hz
           GLX Renderer: Gallium 0.4 on llvmpipe (LLVM 4.0, 256 bits)
           GLX Version: 3.0 Mesa 17.0.2
Audio:     Card Intel Device a171 driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture v: k4.10.0-40-generic
Network:   Card-1: Qualcomm Atheros Device e0b1 driver: alx
           IF: enp61s0 state: down mac: <filter>
           Card-2: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
           driver: ath10k_pci
           IF: wlp62s0 state: down mac: <filter>
           Card-3: Atheros
           IF: null-if-id state: N/A speed: N/A duplex: N/A mac: N/A
Drives:    HDD Total Size: 1288.2GB (0.7% used)
           ID-1: /dev/sda model: TOSHIBA_THNSNJ25 size: 256.1GB
           ID-2: /dev/sdb model: HGST_HTS541010B7 size: 1000.2GB
           ID-3: USB /dev/sdc model: USB_2.0_FD size: 31.9GB
Partition: ID-1: swap-1 size: 1.04GB used: 0.00GB (0%) fs: swap dev: /dev/zram0
           ID-2: swap-2 size: 1.04GB used: 0.00GB (0%) fs: swap dev: /dev/zram1
           ID-3: swap-3 size: 1.04GB used: 0.00GB (0%) fs: swap dev: /dev/zram2
           ID-4: swap-4 size: 1.04GB used: 0.00GB (0%) fs: swap dev: /dev/zram3
           ID-5: swap-5 size: 1.04GB used: 0.00GB (0%) fs: swap dev: /dev/zram4
           ID-6: swap-6 size: 1.04GB used: 0.00GB (0%) fs: swap dev: /dev/zram5
           ID-7: swap-7 size: 1.04GB used: 0.00GB (0%) fs: swap dev: /dev/zram6
           ID-8: swap-8 size: 1.04GB used: 0.00GB (0%) fs: swap dev: /dev/zram7
Sensors:   System Temperatures: cpu: 52.0C mobo: 27.8C
Info:      Processes: 227 Uptime: 1 min Memory: 402.3/15928.7MB
Should I try to install it now from the onscreen icon?
« Last Edit: December 13, 2017, 02:46:17 am by adamunderwood »
« Reply #5 on: December 13, 2017, 02:48:48 am »
Hi adamunderwood,
Yes, give it a go and if it stalls on boot again - use nomodeset to get it to a desktop
One installed you should be able to install nvidia drivers which should negate the need for future use of nomodeset
Good Luck  :)
Linux User #565092
  • Still learning
« Reply #6 on: December 13, 2017, 02:58:22 am »
Thanks for the help, so far it is working.  So with this computer do you recommend me to use Logical Volume Management or no?
« Reply #7 on: December 13, 2017, 03:02:37 am »
Good to hear  :)
That's your own personal choice. I have never used it so am not in a position to recommend or not - sorry.
Linux User #565092
  • Still learning
« Reply #8 on: December 13, 2017, 03:16:14 am »
Well it appears that the install worked.
Thank you very much for your help.
So is it a major pain to explain what you think my problem was?
« Reply #9 on: December 13, 2017, 03:21:07 am »
Hi
I am glad it worked but I am not technical enough to explain why it just didn't work.    New motherboard - new graphics card - dual graphics card as I saw you had intel graphics too??
All I know is the tips n tricks I have learnt whilst on the Forums.
Hopefully someone more technical will come along with a "possible" answer  :)
Linux User #565092
  • Still learning
Re: Problem installing peppermint8 to new laptop [SOLVED]
« Reply #10 on: December 13, 2017, 03:22:50 am »
I can accept that.
Thank you once again for your help.
Take care.
Adam Underwood
