Author Topic: Where is Peppermint's "About" screen?  (Read 1424 times)
Offline stefanreich
  • Bot maker
    • Custom chat bots
« on: December 09, 2017, 05:07:44 pm »
This is something that strikes me as odd. I try to find out which version I'm running ( 7 or 8 ) and I don't find anything in the start menu.
Where is your big, proud "This is Peppermint Version X"?
Microsoft used to put that information right in the start menu (though they seem to have stopped doing that).
I make the best AI ever. https://BotCompany.de
Re: Where is Peppermint's "About" screen?
« Reply #1 on: December 09, 2017, 06:25:25 pm »
There are a number of methods you can use to find out what version you're using.  One is to simply run this in a terminal:
inxi -F
That will give you all kinds of info about your system, including what OS you're using.
Another is to simply hit the "logout" thing in the menu:
There are other ways you can find out, but those are a couple of simple ones.  I don't think there's an "about" page in Peppermint.
« Reply #2 on: December 09, 2017, 07:16:14 pm »
But Peppermint version X isn't out yet , we're only at version VIII :))
And we're not Microsoft.
The PoorGuy
  • Guest
« Reply #3 on: December 09, 2017, 07:20:51 pm »
« Last Edit: August 27, 2018, 10:35:56 pm by The PoorGuy »
Offline Dobri
  • Bah
  • Peppermint version(s): TEN (64)
« Reply #4 on: December 10, 2017, 07:15:17 am »
Or  sudo apt-get install neofetch
       neofetch
WARNING: Military software detected, top secret clearance required
« Reply #5 on: December 10, 2017, 10:42:42 am »
It's on Peppermint's default start page.  You click on peppermint home > about
Oh, here's the page.;)
https://peppermintos.com/about/
« Last Edit: December 10, 2017, 11:03:21 am by perknh »
« Reply #6 on: December 10, 2017, 11:43:45 am »
Now now perknh, if I didn't know you better I'd think you were being sarcastic there :))
« Reply #7 on: December 10, 2017, 11:51:41 am »
That was going to be my first response, but I decided to leave that for you and to show a couple easy ways to know your version number.  ;)
Programs like hardinfo (the exact name in the repositories) would be one of the closest things to what Microsoft has, in that it will give you all of the info about your system.  However, not everyone will use it and it's simple to install, so there was no good reason to have it by default.  Also, including it would violate the Peppermint ethos of installing only the bare essentials and letting the end user decide what else should be installed.  To install hardinfo, just run this command in a terminal:
sudo apt-get install hardinfo
Offline stefanreich
  • Bot maker
    • Custom chat bots
« Reply #8 on: December 10, 2017, 02:37:19 pm »
To me you are like the Microsoft.
(It's a compliment  :D)
Thanks dudes, so there are ways to do this, but as often in Unix, they could be more obvious.
Oh and no, the website doesn't cut it, I want to know about _my machine_.
« Last Edit: December 10, 2017, 02:38:57 pm by stefanreich »
« Reply #9 on: December 10, 2017, 03:22:16 pm »
Sorry my mate but Peppermint isn't in the habit of including unnecessary 'stuff' .. it would be trivial to write something to display which version of Peppermint you are using, but I'd expect the vast majority will know, and only a tiny percentage of those that don't would care enough to require an 'app' for it.
And we won't load everyone's system with something most won't need .. it's contrary to the Peppermint ethos ;)
And I'd have thought that peppermint-logout telling you every time it's run would be enough for most ;)
« Last Edit: December 10, 2017, 03:42:22 pm by PCNetSpec »
Offline stefanreich
  • Bot maker
    • Custom chat bots
« Reply #10 on: December 10, 2017, 07:56:29 pm »
       neofetch
sudo apt install neofetch
Reading package lists... Done
Building dependency tree
E: Unable to locate package neofetch
« Reply #11 on: December 10, 2017, 08:08:11 pm »
Which version of Peppermint are you running .. our custom version of neofetch is only in the PM8 respin repos
If you want our custom version of neofetch in PM7 or the original PM8, download this file
Click me
then double click the file to install
« Reply #12 on: December 11, 2017, 07:06:01 am »
No, I naively thought this thread had veered off course early on.  I thought if scifidude79 and The Poor Guy had not answered the questions correctly with the inxi -Fz or lsb_release -a commands, then stefanreich must have been referring to Peppermint's very own About page.
I now see I was wrong about About! ;D
« Reply #13 on: December 11, 2017, 11:05:41 am »
As I said .. if I didn't know you better :))
Offline stefanreich
  • Bot maker
    • Custom chat bots
« Reply #14 on: December 12, 2017, 07:15:53 pm »
Click me
I'm on PM7. Yay, so cool (neofetch's ascii art).
