Author Topic: Peppermint 8 Respin Released  (Read 6019 times)
« on: December 08, 2017, 12:03:21 am »
Team Peppermint are pleased to announce the latest iteration of our operating system Peppermint 8 Respin which still comes in 32bit and 64bit versions with the 64bit version having full UEFI and Secureboot support. Whilst a respin is generally a minor release intended as an ISO update, the Peppermint 8 Respin does contain some significant changes.
Peppermint 8 Respin (Peppermint-8-20171130) changes:-
  • Nemo 2.8.7 updated to Nemo 3.4.7 which seems more stable during large file operations, and now has a separate process for controlling the desktop.
  • OpenVPN updated in the repos to version OpenVPN 2.4.4 to support mixed mode IPv4/IPv6 VPN’s.
  • Switched from lightdm-gtk-greeter to slick-greeter. So a new much prettier login screen, and a GUI utility in the menu called ‘Login Window’ for login screen settings, including the ability to add/change/remove an autologin user.
  • Added a desktop right-click “Open Peppermint Settings Panel” context menu item. We noticed that people who borked or deleted their xfce4-panel had no easy way to get to the Peppermint Settings Panel so they could use the panel reset function to recover, now they can by right-clicking on the desktop.
  • Installed mint-translations, so included mint applications are now available with non-English translations.
  • Fixed peppermint-proxy-configuration on the 32bit ISO.
  • Improved i3lock lock-screen, similar to the previous one but with a neater looking clock that can be changed between 12hr and 24hr.
  • Advert Blocker reinstated by request, available in the main menu not in the Peppermint Settings Panel.
  • New “Pepirus” xfwm4 theme similar to the Peppermint 7 xfwm4 theme but the active window has a light grey border instead of blue, and some small colour tweaks. Most users said they preferred the Peppermint 7 window borders to the Peppermint 8 ones, so this is a ‘similar’ but updated theme.
  • New “Pepirus” icon theme with red folders, and additional icons.
  • New “Pepirus” Gtk theme similar to Peppermix-7-Dark-Red to fit with the new red icon and xfwm4 themes.
  • Changed default wallpaper to Peppermint-3D-Logo-Alternative.
  • Three additional Ray Bilcliff wallpapers.
  • Disabled Gtk overlay scrollbars, so the scrollbars don’t overlay other window content making it difficult to see.
  • Repository now contain tweaked versions of screenfetch and neofetch with custom Peppermint logo ASCII art.
  • Slightly larger terminal window defaults so neofetch/screenfetch have the room necessary to display properly.
  • Started adding non-English translated versions of ICE to the repos .. more languages will be added later as we create them (we’re putting in a lot of effort into having full non-English translations for ALL applications hopefully by Peppermint 9).
  • ISO’s now contain all 16.04 updates (to the date of the ISO) .. so the Peppermint 8 respin ISO’s ship with the 4.10.0-40 kernel from the HWE, which will automatically roll onto the 4.13 kernel via the update-manager when the HWE updates upstream (probably around February).
I should probably explain here that some people have suggested the 4.10 kernel series is no longer supported, whilst this may be true for the vanilla kernel please rest assured the Ubuntu 4.10 kernel from the HWE (as used here) is fully supported upstream and will be until you’re automatically rolled onto the 4.13 kernel).
Notes:-
One thing to note is nemo’s new desktop right-click context menu item(s) .. if you right-click the desktop then select “Desktop”, make sure you don’t select both:-
Auto-arrange
and:-
Align to grid
at the same time, or you won’t be able to move any desktop icons .. when both are selected desktop icons are locked in place.
(by default only ‘Align to grid’ is selected)
Other things of note are the default repos now contain these terrific apps from the TeeJee repo:-
  • aptik
  • conky-manager
  • selene
  • timeshift
  • timeshift-btrfs
So no need to add a PPA.
We'd like to give a massive thanks to all the people that tested the respin prior to release .. Cheers Guys/Gals, you did us proud AGAIN :)
Re: Peppermint 8 Respin Released
« Reply #1 on: December 08, 2017, 01:02:50 am »
 ;D  ;D  ;D
« Reply #2 on: December 08, 2017, 01:32:23 am »
[emoji847][emoji847][emoji847]
« Reply #3 on: December 08, 2017, 06:21:44 am »
As always, thanks for all your hard work, PCNetSpec.
« Reply #4 on: December 08, 2017, 08:53:41 am »
Thanks scifidude79 .. as always, you're welcome :)
A very complimentary video by English Bob
« Reply #5 on: December 08, 2017, 10:37:36 am »
Quote from: English Bob
Clever little people over at the Peppermint Team [...]
Heh! I'm 6' 3" and 228 lb. but... yeah. You're welcome, EB!
 ;D  ;D  ;D
« Reply #6 on: December 08, 2017, 10:40:13 am »
Damn I hate the way everything slows to a crawl on release days :(
Maybe we should look into something like cloudflare for software distribution.
LOL .. now what's that in real weight (stones) ? .. kiddin ;)
« Reply #7 on: December 08, 2017, 10:46:46 am »
Not sure, but if this was Boxing, I'd be in the Heavyweight class. LoL!  8)
For most boxing organizations, the maximum weight for a cruiserweight is 200 pounds. Thus, a fighter whose weight is over 200 lb (14 st 3 lb, 90 kg) may not fight as anything but a heavyweight.
Offline jlschwartz
  • Forum User
« Reply #8 on: December 08, 2017, 10:49:53 am »
PCNetSpec,
Great job as always.  :)
Offline penrose1950
« Reply #9 on: December 08, 2017, 01:06:08 pm »
Do I have to reinstall or would a update or upgrade be ok please?
Thank you.
« Reply #10 on: December 08, 2017, 01:15:35 pm »
Thank you.
Answer for the same Q on another thread
https://forum.peppermintos.com/index.php/topic,6274.msg63766.html#msg63766
Offline penrose1950
« Reply #11 on: December 08, 2017, 01:28:18 pm »
Thank you.
Offline Peter
  • Peppermint version(s): 7 Respin
« Reply #12 on: December 08, 2017, 01:50:34 pm »
I verified ISO by gtkhash. The program shows  sha256sum for Peppermint 8 Respin (64 bit) the following:
cff39c61273697c011ebe82f851476938ef2b351d9173f49db64043a19e4ff0d
The value on download page:
8ae0a1585752bb3fe38f4cbe4810c9be029702d6bd77b12efe0a4852edde040a
 :-\ However, md5sums are the same. I tried both direct and torrent downloads. What does it mean, thanks!
« Reply #13 on: December 08, 2017, 02:02:02 pm »
I've just fixed that on the main site .. apparently I'd accidentally posted the 32bit SHA256 sum for both ISO's (MD5's were correct) :-[
The checksums are now correct .. thanks for pointing it out :)
Here they are again though:-
Peppermint 8 Respin 64bit
Peppermint-8-20171130-amd64.iso
MD5 = 51137b0f622ee7d44149389e6557e655
SHA256 = cff39c61273697c011ebe82f851476938ef2b351d9173f49db64043a19e4ff0d
Peppermint 8 Respin 32bit
Peppermint-8-20171130-i386.iso
MD5 = 8a2e66ae01fac44b9ee4b421842fae55
SHA256 = 8ae0a1585752bb3fe38f4cbe4810c9be029702d6bd77b12efe0a4852edde040a
Or they can be found here:
https://peppermintos.com/iso/Peppermint-8-20171130-checksums.txt
« Last Edit: December 08, 2017, 02:04:58 pm by PCNetSpec »
Offline Peter
« Reply #14 on: December 08, 2017, 02:41:00 pm »
Many thanks!
