Author Topic: Cant install Broadcom driver for BCM43142 in live session  (Read 1868 times)
Offline mk63
« on: November 23, 2017, 12:09:34 pm »
Hi!
It's my first post here.
Very nice distro Peppermint 8.
I am in live session and trying to connect to my wifi network but there is no driver for my wifi adapter in live media usb.
My hp stream 13 has only wifi adapter, there is no ethernet adapter. I dont have any phone with android at home to connect my laptop to internet via tethering.
How to load driver for my chip BCM43142 in live session without installing to hard drive?
Is there any .deb file with this driver I could download from and install without rebooting as I am in live session?
I have another PC connected to internet, now I am writting on it.
Could anyone help me?
Thanks in advace
Offline mk63
Re: Cant install Broadcom driver for BCM43142 in live session
« Reply #1 on: November 23, 2017, 12:42:14 pm »
System:    Host: peppermint Kernel: 4.8.0-53-generic x86_64 (64 bit)
Machine:   System: HP (portable) product: HP Stream Notebook PC 13 v: Type1 - ProductConfigId
           Mobo: HP model: 802A v: 56.21 Bios: Insyde v: F.17 date: 09/25/2015
CPU:       Dual core Intel Celeron N2840 (-MCP-) cache: 1024 KB
           clock speeds: max: 2582 MHz 1: 566 MHz 2: 583 MHz
Graphics:  Card: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display
           Display Server: X.Org 1.18.4 drivers: (unloaded: fbdev,vesa)
           Resolution: 1366x768@60.06hz
           GLX Renderer: Mesa DRI Intel Bay Trail GLX Version: 3.0 Mesa 17.0.2
Audio:     Card Intel Atom Processor Z36xxx/Z37xxx Series High Definition Audio Controller
           Sound: Advanced Linux Sound Architecture v: k4.8.0-53-generic
Network:   Card: Broadcom BCM43142 802.11b/g/n
           IF: N/A state: N/A mac: N/A
Drives:    HDD Total Size: 2.0GB (47.3% used)
           ID-1: /dev/mmcblk1 model: N/A size: 31.3GB
           ID-2: USB /dev/sda model: TransMemory size: 2.0GB
Partition: ID-1: swap-1 size: 0.50GB used: 0.00GB (0%) fs: swap dev: /dev/zram0
           ID-2: swap-2 size: 0.50GB used: 0.00GB (0%) fs: swap dev: /dev/zram1
Sensors:   System Temperatures: cpu: 39.0C mobo: N/A
Info:      Processes: 161 Uptime: 59 min Memory: 317.8/1894.3MB
« Reply #2 on: November 24, 2017, 07:15:37 am »
Can you post the output from:
lspci -vnn | grep -i net
lsusb
and do you mind adding persistence to this LiveUSB ?
Offline mk63
« Reply #3 on: November 24, 2017, 12:37:33 pm »
hi PCNetSpec!
peppermint@peppermint ~ $ lspci -vnn | grep -i net
02:00.0 Network controller [0280]: Broadcom Corporation BCM43142 802.11b/g/n [14e4:4365] (rev 01)
peppermint@peppermint ~ $ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 0a5c:216c Broadcom Corp. BCM43142A0 Bluetooth Device
Bus 001 Device 006: ID 0930:6544 Toshiba Corp. TransMemory-Mini / Kingston DataTraveler 2.0 Stick (2GB)
Bus 001 Device 003: ID 05e3:0608 Genesys Logic, Inc. Hub
Bus 001 Device 002: ID 0bda:57c4 Realtek Semiconductor Corp.
How to do this?
« Reply #4 on: November 24, 2017, 04:24:24 pm »
Yep, you need the bcmwl-kernel-source drivers, so the first thing you're going to want to do is make the USB stick persistent.
How did you create the LiveUSB stick ?
And what capacity is your USB stick ?
« Last Edit: November 24, 2017, 04:26:22 pm by PCNetSpec »
Offline mk63
« Reply #5 on: November 26, 2017, 06:40:22 am »
USB stick is 2G.
I made it under linux Mint by something like usb image wtiter.
I know I need bcmwl-kernel source driver, some distros have it in live media, so I can try internet connection in live session.
I would like to purge win10 from my laptop, it has only 32G storage memory.
Unfortunatly some linux distros have poor driver for my wifi adapter compared to windows driver.
« Reply #6 on: November 26, 2017, 08:18:41 am »
Because of the way "USB Image Writer" works, there is no way to add a persistence file to that LiveUSB.
If you use something like Rufus to create the LiveUSB you can .. see here:
https://forum.peppermintos.com/index.php/topic,6141.msg62132.html#msg62132
« Reply #7 on: November 26, 2017, 12:21:34 pm »
I've had good luck with UNetbootin, too...
  • Download the ISO via Torrent (Transmission app)
  • Bake the USB stick using UNetbootin (1000mb persistence)
