Author Topic: [SOLVED] Peppermint 8 Kernel  (Read 770 times)
The PoorGuy
  • Guest
« on: October 31, 2017, 05:14:31 am »
« Last Edit: August 27, 2018, 07:11:28 pm by The PoorGuy »
Re: Peppermint 8 Kernel
« Reply #1 on: October 31, 2017, 08:17:00 am »
The current kernel (as of 31 Oct 2017)  is 4.10.0-38
Unless you've pinned the kernel you shouldn't have to do anything to manually install it .. the update manager should do it for you.
The PoorGuy
  • Guest
« Reply #2 on: October 31, 2017, 08:33:06 am »
« Last Edit: August 27, 2018, 07:11:10 pm by The PoorGuy »
The PoorGuy
  • Guest
« Reply #3 on: October 31, 2017, 05:21:15 pm »
« Last Edit: August 27, 2018, 07:10:56 pm by The PoorGuy »
« Reply #4 on: October 31, 2017, 05:59:21 pm »
Well you could, but you'll find the 4.8, 4.10 (hwe-16.04 <-- this is the default for PM8) and 4.11 kernels ..I'd suggest you stick with the current default kernel as it will soon get rolled onto the 4.13 series automagically.
Seriously, stick with the default and just let it update automatically unless you have a specific reason not to.
« Last Edit: October 31, 2017, 06:07:42 pm by PCNetSpec »
The PoorGuy
  • Guest
« Reply #5 on: October 31, 2017, 06:06:43 pm »
« Last Edit: August 27, 2018, 07:10:34 pm by The PoorGuy »
« Reply #6 on: October 31, 2017, 06:11:20 pm »
Okay I getcha :)
Look in synaptic for the package linux-image-generic-hwe-16.04 .. that's the metapackage that updates the kernel in Peppermint 8 so should always have the same version number the current Peppermint 8 kernel ;)
Or you can run:
sudo apt-get update && clear && apt-cache policy linux-image-generic-hwe-16.04
« Last Edit: October 31, 2017, 06:33:12 pm by PCNetSpec »
The PoorGuy
  • Guest
« Reply #7 on: October 31, 2017, 06:26:19 pm »
« Last Edit: August 27, 2018, 07:09:44 pm by The PoorGuy »
