Author Topic: Applet PROXY in Control Center isn't started  (Read 953 times)
Offline Denisjuk
« on: October 04, 2017, 06:52:15 am »
Hi!
Proxy applet in Control Center isn't started in the x86 version, no corrections and updates at installation were established and the applet doesn't work in original assembly of Peppermint-8-20170527-i386.iso
i.e. I press also any result...
In x64 everything is normal
there are ideas how to repair in the x86 version?
Re: Applet PROXY in Control Center isn't started
« Reply #1 on: October 04, 2017, 07:52:17 am »
What happens if you run:
peppermint-proxy-configurationin a terminal ?
Offline Denisjuk
« Reply #2 on: October 05, 2017, 06:11:03 am »
execute format error
here a screenshot with usb-stick live-session Peppermint-8-20170527-i386:
https://i.imgur.com/2Yyuk8i.png
peppermint@peppermint ~ $ peppermint-proxy-configuration
bash: /usr/bin/peppermint-proxy-configuration: cannot execute binary file: Exec format error
peppermint@peppermint ~ $ inxi -F
System:    Host: peppermint Kernel: 4.8.0-53-generic i686 (32 bit) Desktop: N/A Distro: Peppermint Eight
Machine:   Mobo: MICRO-STAR model: MS-7360 v: 1.0 Bios: American Megatrends v: V1.9 date: 07/03/2008
CPU:       Dual core Intel Core2 Duo E8400 (-MCP-) cache: 6144 KB
           clock speeds: max: 3003 MHz 1: 2003 MHz 2: 2003 MHz
Graphics:  Card: NVIDIA G94 [GeForce 9600 GT]
           Display Server: X.Org 1.18.4 drivers: nouveau (unloaded: fbdev,vesa) Resolution: 1920x1080@60.00hz
           GLX Renderer: Gallium 0.4 on NV94 GLX Version: 3.0 Mesa 17.0.2
Audio:     Card Intel 82801I (ICH9 Family) HD Audio Controller driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture v: k4.8.0-53-generic
Network:   Card: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller driver: r8169
           IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: 00:19:db:cc:8b:9c
Drives:    HDD Total Size: 42.0GB (9.9% used) ID-1: /dev/sda model: WDC_WD400JB size: 40.0GB
           ID-2: USB /dev/sdb model: DT_101_II size: 2.0GB
Partition: ID-1: swap-1 size: 2.05GB used: 0.00GB (0%) fs: swap dev: /dev/sda1
           ID-2: swap-2 size: 0.53GB used: 0.00GB (0%) fs: swap dev: /dev/zram0
           ID-3: swap-3 size: 0.53GB used: 0.00GB (0%) fs: swap dev: /dev/zram1
Sensors:   System Temperatures: cpu: 36.0C mobo: N/A gpu: 39.0
Info:      Processes: 155 Uptime: 9 min Memory: 258.2/2012.4MB Client: Shell (bash) inxi: 2.2.35
« Last Edit: October 05, 2017, 06:17:42 am by Denisjuk »
« Reply #3 on: October 05, 2017, 10:41:49 am »
Okay for Peppermint 32bit, please try this...
cd /usr/binthen
sudo wget https://peppermintos.info/misc/peppermint-proxy-configuration-32bit.tar.gzthen
sudo tar xvf peppermint-proxy-configuration-32bit.tar.gzNow see if the Peppermint Proxy Configuration utility works ?
Offline Denisjuk
« Reply #4 on: October 05, 2017, 01:38:56 pm »
cd /usr/binthen
Yes!
Remarkably! You are the best!!!!
Please make these changes in iso or write on the website...
In total on a screenshot!
https://imgur.com/swJ6ilw
Thanks!!!!!!
Personal request - add to the following release a mint-translations package from LinuxMint, the pix and update manager programs will be always on the lips the user!
forgive for my bad English - the bear with a balalayka prevents to learn all life... and the wife with a vodka bottle :)
« Last Edit: October 05, 2017, 01:45:05 pm by Denisjuk »
« Reply #5 on: October 05, 2017, 04:17:45 pm »
This will be applied on the Peppermint 8 respin when it's released :)
