Author Topic: ASUS E200HA (Cherry Trail CPU)  (Read 4179 times)
Offline Crumbz
  • Systems Engineer
    • Canada eCoin
  • Peppermint version(s): Peppermint 8 64-Bit
« on: October 03, 2017, 02:36:17 pm »
Hello, I am trying to install the 64bit version of Peppermint 8 onto my ASUS E200HA and am having some trouble.
I have been meaning to install Peppermint for some time now as its usually what I run on my laptop... however when I bought this one I discovered the Linux Kernel hadn't added support for the Z type processors from Intel (Cherry Trail). Now that the driver support has been confirmed to have been added, I figured id give it another go.
This time the LIVE Disk runs without issue.. except in the case of the keyboard. Whenever I press a key (does not matter which one I press) rather then displaying the pressed key it brings up the power menu. Touchpad, Wifi, Bluetooth work fine, I haven't tested the audio yet.
So my question is, is there a way to get this distro working correctly on this hardware, and if so has anyone else had success with doing so?
- Crumbz
Check Out Canada eCoin - A Canadian Cryptocurrency - https://canadaecoin.site/
Re: ASUS E200HA (Cherry Trail CPU)
« Reply #1 on: October 04, 2017, 09:39:19 am »
Have you got access to a Linux PC ?
If so, you could try using Linuxiums isorespin.sh shell script to respin the Peppermint 8 ISO image with the "--atom" option .. then burning the respun ISO to a LiveUSB
Create a directory on your desktop called linuxium-peppermint
mkdir ~/Desktop/linuxium-peppermintdownload the Linuxium isorespin.sh shell script from here:
http://linuxiumcomau.blogspot.com/2017/06/customizing-ubuntu-isos-documentation.html
by clicking on the orange isorespin.sh link
Place the downloaded isorespin.sh file into the linuxium-peppermint directory on your desktop.
back in the terminal change directory to the linuxium-peppermint directory:
cd ~/Desktop/linuxium-peppermintdownload the Peppermint 8 64bit ISO image into it
wget https://peppermintos.com/iso/Peppermint-8-20170527-amd64.isomake the isorespin.sh file executable:
chmod +x isorespin.shrun the isorespin.sh shell script on the Peppermint-8-20170527-amd64.iso file with the "--atom" option:
./isorespin.sh -i Peppermint-8-20170527-amd64.iso --atomOR if you also want the 4.11.12 kernel
./isorespin.sh -i Peppermint-8-20170527-amd64.iso --atom -k v4.11.12(enter your password if/when asked)
when that command is finished, you should find an ISO called "linuxium-atom-Peppermint-8-20170527-amd64.iso" (or "linuxium-atom-v4.11.12-Peppermint-8-20170527-amd64.iso" if you added the 4.11.12 kernel) in the linuxium-peppermint direectory on your desktop .. use whatever method to burn this to a USB stick.
« Last Edit: October 04, 2017, 09:54:56 am by PCNetSpec »
Offline Crumbz
  • Systems Engineer
    • Canada eCoin
« Reply #2 on: October 28, 2017, 06:07:34 am »
Thank you, i will have to give this a try. Would running this on a VM make a difference?
Sent from my Redmi Note 4 using Tapatalk
« Reply #3 on: October 28, 2017, 06:16:11 am »
You're supposed to have at least 10GB free for the respinning process, so bear that in mind. Otherwise, I can't see why it wouldn't work on a VM.
Offline Crumbz
  • Systems Engineer
    • Canada eCoin
« Reply #4 on: December 03, 2017, 04:42:05 pm »
Well i have finally had the time to try this and im having mixed results. The respin went fine and they keyboard and wifi work flawlessly... But my audio is expereincing issues, flicking off and on.
« Reply #5 on: December 03, 2017, 05:21:41 pm »
What kernel are you on? What's the output of
uname -r
Offline Crumbz
  • Systems Engineer
    • Canada eCoin
« Reply #6 on: December 03, 2017, 05:24:37 pm »
uname -r
Version 4.11.12-041112-generic
« Reply #7 on: December 03, 2017, 07:03:17 pm »
a)  Have you done a full update?
b)  In the menu > Preferences > Software & Updates;
In the Additional Drivers tab, you could try enabling Processor microcode firmware.
Offline Crumbz
  • Systems Engineer
    • Canada eCoin
« Reply #8 on: December 03, 2017, 09:36:56 pm »
I have run both sudo apt-get update and upgrade, both have not changed anything. And microcode firmware dosent seem to change anything either.
I have tried uninstalling pulseaudio but that dosent change the behaviour. That being said i dont believe the issue lies with pulseaudio.
To describe the issue the audio appears to mute/unmute every 5 seconds. Attempts to access the audio settings shows a loading status, flicks onto the settings page then just as quickly back to the loading status.
« Last Edit: December 03, 2017, 09:38:51 pm by TM33z »
« Reply #9 on: December 04, 2017, 03:58:33 am »
Can you post your full
inxi -Fzoutput so people can see what hardware you have .. it might help troubleshoot the sound.
Offline Crumbz
  • Systems Engineer
    • Canada eCoin
« Reply #10 on: December 04, 2017, 09:34:32 am »
System:    Host: R-PC Kernel: 4.11.12-041112-generic x86_64 (64 bit)
Machine:   Mobo: ASUSTeK model: E200HA v: 1.0
           Bios: American Megatrends v: E200HA.303 date: 12/21/2016
CPU:       Quad core Intel Atom x5-Z8350 (-MCP-) cache: 1024 KB
           clock speeds: max: 1920 MHz 1: 489 MHz 2: 847 MHz 3: 504 MHz
           4: 583 MHz
Graphics:  Card: Intel Device 22b0
           Display Server: X.Org 1.19.3 drivers: (unloaded: fbdev,vesa)
           Resolution: 1366x768@60.06hz
           GLX Renderer: Mesa DRI Intel HD Graphics (Cherrytrail)
           GLX Version: 3.0 Mesa 17.0.2
Audio:     Card Intel HDMI/DP LPE Audio driver: HdmiLpeAudio
           Sound: Advanced Linux Sound Architecture v: k4.11.12-041112-generic
Network:   Card: Qualcomm Atheros Device 0042 driver: ath10k_pci
           IF: wlp1s0 state: up speed: N/A duplex: N/A mac:
Drives:    HDD Total Size: NA (-) ID-1: /dev/mmcblk0 model: N/A size: 31.3GB
Partition: ID-1: / size: 25G used: 5.0G (22%) fs: ext4 dev: /dev/mmcblk0p2
           ID-2: swap-1 size: 4.18GB used: 0.00GB (0%) fs: swap dev: /dev/mmcblk0p3
Sensors:   System Temperatures: cpu: 33.0C mobo: N/A
           Fan Speeds (in rpm): cpu: 0
Info:      Processes: 188 Uptime: 10 min Memory: 286.6/3844.2MB
« Last Edit: December 04, 2017, 09:52:13 am by TM33z »
« Reply #11 on: December 04, 2017, 10:07:17 am »
are you using an external HDMI monitor ?
What's the output from:
lsmod | grep sndand
aplay -l?
Offline Crumbz
  • Systems Engineer
    • Canada eCoin
« Reply #12 on: December 04, 2017, 10:17:30 am »
I do not use an HDMI monitor, only the built in monitor.
here is the out put from lsmod | grep snd:
snd_soc_rt5645        147456  0
snd_soc_rl6231         16384  1 snd_soc_rt5645
snd_hdmi_lpe_audio     24576  1
snd_intel_sst_acpi     16384  0
snd_intel_sst_core     77824  1 snd_intel_sst_acpi
snd_soc_sst_atom_hifi2_platform   102400  1 snd_intel_sst_core
snd_soc_sst_match      16384  1 snd_intel_sst_acpi
snd_soc_core          229376  2 snd_soc_sst_atom_hifi2_platform,snd_soc_rt5645
snd_compress           20480  1 snd_soc_core
ac97_bus               16384  1 snd_soc_core
snd_pcm_dmaengine      16384  1 snd_soc_core
snd_pcm               102400  5 snd_hdmi_lpe_audio,snd_pcm_dmaengine,snd_soc_sst_atom_hifi2_platform,snd_soc_rt5645,snd_soc_core
snd_seq_midi           16384  0
snd_seq_midi_event     16384  1 snd_seq_midi
snd_rawmidi            32768  1 snd_seq_midi
snd_seq                65536  2 snd_seq_midi_event,snd_seq_midi
snd_seq_device         16384  3 snd_seq,snd_rawmidi,snd_seq_midi
snd_timer              32768  2 snd_seq,snd_pcm
snd                    77824  11 snd_compress,snd_seq,snd_hdmi_lpe_audio,snd_timer,snd_soc_sst_atom_hifi2_platform,snd_rawmidi,snd_seq_device,snd_soc_core,snd_pcm
soundcore              16384  1 snd
And the output form aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: Audio [Intel HDMI/DP LPE Audio], device 0: HdmiLpeAudio [Intel HDMI/DP LPE Audio]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
The strangest part is if i leave the sound settings windows open long enough it seems to catch there is an audio device and stops flickering. But alas the audio still does not work as it only detects the HDMI audio but no output device beyond that.
And on another note i discovered that streamed videos (youtube) play at proper speed while the audio is flicking, but after stopping the flicking the same video plays at 400x speed with no audio.
« Reply #13 on: December 04, 2017, 10:27:01 am »
Have you seen the scripts here:
https://github.com/Grippentech/Asus-E200HA-Linux-Post-Install-Script
(which appears to download a custom 4.12 series kernel and some config files for audio for the E200HA)
I can tell you how to run them (or simply how to manually run what's in the JustSound script), but if they screw things up are you okay to reinstall ?
« Last Edit: December 04, 2017, 10:31:16 am by PCNetSpec »
Offline Crumbz
  • Systems Engineer
    • Canada eCoin
« Reply #14 on: December 04, 2017, 10:43:49 am »
Yes i am good to reinstall if need be, id like to get this working.
I will try running those scripts
