Author Topic: How to Auto run Virtual Box VM automatically -SOLVED  (Read 1370 times)
Offline rajeev2631007
« on: September 27, 2017, 08:22:24 am »
Hi,
I want to autorun virtual box VM automatically. I had googled this and found.
VBoxManage startvm "Zentyal" -type headless
When I tried this in terminal, It's works there. But When I had added above command in autostart option and restart Linux.
Peppermint-Setting-Panel-->System-->LxSession Configuration-->autostart-->Add Manual autostarted application
But it is not working with autostart option.
Please suggest me solution.
Rajeev Gautam
« Last Edit: October 11, 2017, 01:00:17 pm by rajeev2631007 »
Re: How to Auto run Virtual Box VM automatically
« Reply #1 on: September 27, 2017, 10:44:46 am »
Autostart commands run from there are system wide so VBoxManage wouldn't know where to find the "Zentyal" vbox image.
So you'd think maybe adding the full path to the vbox would work, as in (something like):
VBoxManage startvm "/home/rajeev/VirtualBox VMs/Zentyal/Zentyal.vbox" -type headless
would work right ? .. well it doesn't (I'm guessing) because it doesn't know who to run VBoxManage as.
So the best way to autostart the vbox would probably be to autostart it from the "users" autostart folder.
Run:
pluma ~/.config/autostart/zentyal-vbox.desktop
When a blank file opens, make it read:-
[Desktop Entry]
Type=Application
Version=1.0
Name=Zentyal Virtaulbox
Comment=Autostart the Zentyal Virtualbox
Exec=VBoxManage startvm "Zentyal" -type headless
Icon=virtualbox
Terminal=false
SAVE the file, and exit the text editor.
Now test it by logging off/on again.
Thinking about it, if the vbox is going to rely on a wireless network to come up before the vbox, it might be necessary to build a delay into the autostart command that allows the wireless time to come up first, such as by making the "Exec=" line read say:-
Exec=sleep 10 ; VBoxManage startvm "Zentyal" -type headless
I'm assuming you realise the "-type headless" is going to stop the vbox GUI from being displayed locally ? .. it'll be running, but you won't see the vbox on screen.
« Reply #2 on: September 29, 2017, 01:28:57 pm »
Hi,
PCNetSpecs Thanks.
Run:
[Desktop Entry]
Type=Application
Version=1.0
Exec=VBoxManage startvm -type headless
Icon=virtualbox
Terminal=false
Above instrcutions works for me.I have one more question when I'll shutdown VirtualBox Host OS it will poweroff specifiy running VM before shutdown Host OS.
VBoxManage controlvm "Zentyal"  poweroff
Thanks again for your help.
Rajeev Gautam
« Reply #3 on: September 29, 2017, 01:35:16 pm »
Are you asking how to run:
if you shut down the PC using the normal shutdown procedure of clicking the logout button in the whiskerrmenu ? .. or do you use some other method of powering off your PC
« Reply #4 on: September 29, 2017, 01:57:04 pm »
Hi,
I'm asking given below syntax should run automatically and poweroff VM when I shutdown Host OS. I mean given syntax run automatically and poweroff before shutdown Host OS.
Rajeev Gautam
« Reply #5 on: September 29, 2017, 02:53:49 pm »
Yeah but how do you normally shut down the host PC ?
« Reply #6 on: September 29, 2017, 03:16:00 pm »
Hi,
Click on Menu-->Logout-->Shutdown
Rajeev Gautam
« Reply #7 on: September 30, 2017, 02:02:13 pm »
Okay I'll have a look at this tomorrow and see what I can come up with .. it should be easy to enough to create an rc.d init script to run at shutdown, but I need to test it and how:-
a) they work with systemd
b) if it somehow needs to be run as the user VBoxManage is running as
« Reply #8 on: October 11, 2017, 12:59:35 pm »
Hi,
Create vmstop.service file \etc\systemd\system\vmstop.service and copy given below code.
[Unit]
Description=Do something required
DefaultDependencies=no
Before=shutdown.target reboot.target halt.target
# This works because it is installed in the target and will be
#   executed before the target state is entered
# Also consider kexec.target
[Service]
Type=oneshot
ExecStart=/home/administrator/shutdown.sh  #your path and filename
[Install]
WantedBy=halt.target reboot.target shutdown.target
Enable this Service
systemctl enable vmstop.service
systemctl start vmstop.service
systemctl status vmstop.service
create bash script /home/administrator/shutdown.sh
#!/bin/bash
Rajeev Gautam
Re: How to Auto run Virtual Box VM automatically -SOLVED
« Reply #9 on: October 11, 2017, 03:46:36 pm »
Thanks for the solution rajeev, I completely lost this topic somewhere in the ether :-[
