Author Topic: how do i tell what version i am using?  (Read 1045 times)
Offline wizvac
  • Peppermint version(s): Peppermint?
« on: September 23, 2017, 09:03:48 am »
Please help!
Re: how do i tell what version i am using?
« Reply #1 on: September 23, 2017, 09:18:10 am »
Type this into a terminal:
You'll get a whole list of stuff, including the Peppermint version.
« Reply #2 on: September 23, 2017, 09:56:50 am »
The version is also visible when you shutdown from the menu.
"Logout Peppermint ... session?"
« Reply #3 on: September 23, 2017, 11:00:47 am »
Or you can run:
cat /etc/lsb-release
Offline josephd
  • Peppermint OS Website Admin
    • LinuxBookPro
« Reply #4 on: September 23, 2017, 02:03:32 pm »
Another method: Go to the Menu and look for the Software & Updates It's in the Preferences sub group. Then visit the Other Software tab. This tab along with the rest is a great way to find at a glance information on your Ubuntu based system.
Offline Admiral_Smith
  • Peppermint version(s): 7
« Reply #5 on: October 10, 2017, 09:28:58 pm »
uname -a
« Reply #6 on: October 11, 2017, 12:41:18 am »
uname -a
That gives you the kernel currently running, not the OS version.
Offline VinDSL
« Reply #7 on: October 11, 2017, 11:22:41 am »
vindsl@Chi-You ~ $ lsb_release -irc
Distributor ID: Peppermint
Release: 7
Codename: xenial
