Author Topic: Boot issue  (Read 1207 times)
Offline cizz
Boot issue
« on: August 25, 2017, 05:37:11 am »
Hi, I am having an issue while booting.  We have several of same computers and so far have tested 6. They all boot properly when first installed (fresh or cloned HD).  1 of them boots properly regularly, while the others have issues. Upon starting get the HP splash, the screen glows for a bit then goes off and remains off until lid is closed and reopened, power pressed to wake and the screen comes back on.  The one working properly gets splash, glows, goes out then glows again and loads.
cizz@cizz-HP-ProBook-6565b ~ $ inxi -Fz
System:    Host: cizz-HP-ProBook-6565b Kernel: 4.10.0-32-generic x86_64 (64 bit)
Machine:   System: Hewlett-Packard (portable) product: HP ProBook 6565b v: A0001D02
           Mobo: Hewlett-Packard model: 1635 v: KBC Version 03.1B
           Bios: Hewlett-Packard v: 68LTU Ver. F.20 date: 11/14/2011
CPU:       Dual core AMD A4-3310MX APU with Radeon HD Graphics (-MCP-) cache: 2048 KB
           clock speeds: max: 2100 MHz 1: 1800 MHz 2: 1200 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Sumo [Radeon HD 6480G]
           Display Server: X.Org 1.19.3 drivers: ati,radeon (unloaded: fbdev,vesa)
           Resolution: 1366x768@60.03hz
           GLX Renderer: Gallium 0.4 on AMD SUMO (DRM 2.49.0 / 4.10.0-32-generic, LLVM 4.0.0)
           GLX Version: 3.0 Mesa 17.0.2
Audio:     Card-1 Advanced Micro Devices [AMD] FCH Azalia Controller
           Card-2 Advanced Micro Devices [AMD/ATI] BeaverCreek HDMI Audio [Radeon HD 6500D and 6400G-6600G series]
           Sound: Advanced Linux Sound Architecture v: k4.10.0-32-generic
Network:   Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
           driver: r8169
           IF: enp1s0 state: down mac: <filter>
           Card-2: Broadcom BCM4313 802.11bgn Wireless Network Adapter
           driver: wl
Drives:    HDD Total Size: 120.0GB (11.8% used)
           ID-1: /dev/sda model: SAMSUNG_HM121HJ size: 120.0GB
Partition: ID-1: / size: 107G used: 10G (10%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 3.69GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 30.0C mobo: 0.0C gpu: 34.0
Info:      Processes: 220 Uptime: 13:05 Memory: 595.4/3414.3MB
« Last Edit: August 25, 2017, 06:18:28 am by scifidude79 »
Re: Boot issue
« Reply #1 on: August 25, 2017, 06:34:17 am »
Have you tried the "nomodest" kernel boot parameter ?
If you're not sure how, just ask.
BTW, welcome to the forum :)
« Last Edit: August 25, 2017, 06:40:50 am by PCNetSpec »
Offline cizz
Re: Boot issue
« Reply #2 on: August 25, 2017, 06:43:08 am »
I did try something I found in various forums involving 'nomodest', willing to try again with more specific directions and for discussion purposes.
and THANX for havin me  :D
clic
read back thru forum and found the post I had read about 'nomodest' as a 1 time thing, if i shift after initial flash and enter on peppermint it loads fine ...so possibly an issue with my grub loader? Still seems odd that one of the group work fine (when switching HD around)
GRUB_DEFAULT=0
GRUB_HIDDEN_TIMEOUT=0
GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX=""
« Last Edit: August 25, 2017, 08:35:29 am by cizz »
Re: Boot issue
« Reply #3 on: August 25, 2017, 11:26:29 am »
Sorry got called away .. I'm a bit confused by your reply, does it mean you HAVE tried nomodeset or not ?
And are we talking about a blanks screen (black but baclights on), or a black screen (black with backlights off) ?
