Author Topic: Unpredictable System Behavior In Some Intel Processors  (Read 2956 times)
Re: Unpredictable System Behavior In Some Intel Processors
« Reply #15 on: August 11, 2017, 07:53:03 am »
That line you quoted wasn't aimed at anyone, it was purely a humorous attempt to accentuate the "probably best to just wait" sentiment ;)
Offline cavy
  • Caveman
« Reply #16 on: August 11, 2017, 08:02:00 am »
Any advice?! Should I disable hyper-threading and if so, how?
I've been running HT since 2004, 32-bit and 64-bit.  Leave it enabled.
Also, if you're running a hot chip:  https://goo.gl/2bmWkv  I've run 4 GHz on air, with this stuff   ;)
It took me a while to realise HT was hyper threading. HT to me usually mean high tension cable for your spark plugs, lol....!
 So okay another lesson, learnt, cheers.... :D  there's thermal paste and there's thermal paste. I bought HY150 for to do maintenance on my computers. This is the most expensive on ebay http://tinyurl.com/yblojrpw
Offline cavy
  • Caveman
« Reply #17 on: August 11, 2017, 08:03:38 am »
it tickled my funny bone   :D
