Author Topic: terminal error : Could not load Gedit repository  (Read 4938 times)
« on: July 01, 2014, 05:25:48 pm »
anybody got a clue about how to rectify this?
spence@hpG6 ~ $ sudo gedit
[sudo] password for spence:
** (gedit:2291): WARNING **: Could not load Gedit repository: Typelib file for namespace 'GtkSource', version '3.0' not found
a duckduck search tells me to use gksudo instead of sudo?
http://askubuntu.com/questions/369915/warnings-while-launching-gedit-from-the-ubuntu-terminal
since that post is dated prior to P5s release I'll await instruction from here...
Re: terminal error : Could not load Gedit repository
« Reply #1 on: July 01, 2014, 05:36:45 pm »
well gksudo gedit eliminates the error message.... dunno why though yet... learning something new every day...
Offline kendall
  • Co-Founder
« Reply #2 on: July 01, 2014, 06:26:27 pm »
It's just a warning so it won't affect the actual function of the application. In addition to running it with gksudo you can install the package "gir1.2-gtksource-3.0" which should eliminate the warning.
« Reply #3 on: July 02, 2014, 12:51:36 am »
I believe that you should in general start GUI-based programs using gksudo and CLI-programs (i.e. those without a graphical user interface) by using sudo;)
