Author Topic: Kernel Update Help! [Solved]  (Read 1645 times)
Offline acer
« on: August 04, 2017, 09:20:51 am »
System:    Host: HP-Notebook Kernel: 4.4.0-87-lowlatency x86_64 (64 bit)
Machine:   System: Hewlett-Packard product: HP G60 Notebook PC v: PCID
           Mobo: Hewlett-Packard model: 3617 v: 09.67
           Bios: Hewlett-Packard v: F.65 date: 12/15/2010
CPU:       Dual core Intel Core2 Duo T5800 (-MCP-) cache: 2048 KB
           clock speeds: max: 2000 MHz 1: 1200 MHz 2: 1600 MHz
Graphics:  Card: NVIDIA G98M [GeForce 9200M GS]
           Display Server: X.Org 1.18.4 drivers: nouveau (unloaded: fbdev,vesa)
           Resolution: 1366x768@60.11hz
           GLX Renderer: Gallium 0.4 on NV98 GLX Version: 3.0 Mesa 17.0.7
Audio:     Card Intel 82801I (ICH9 Family) HD Audio Controller
           Sound: Advanced Linux Sound Architecture v: k4.4.0-87-lowlatency
Network:   Card-1: Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
           driver: r8169
           IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
           Card-2: Qualcomm Atheros AR242x / AR542x Wireless Network Adapter (PCI-Express)
           driver: ath5k
           IF: wlp3s0 state: down mac: <filter>
Drives:    HDD Total Size: 60.0GB (17.0% used)
           ID-1: /dev/sda model: OCZ size: 60.0GB
Partition: ID-1: / size: 51G used: 5.8G (12%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 4.26GB used: 0.00GB (0%) fs: swap dev: /dev/dm-0
Sensors:   System Temperatures: cpu: 43.0C mobo: 42.0C gpu: 46.0
Info:      Processes: 195 Uptime: 57 min Memory: 684.5/3919.0MB
Looking for some help to get back on the normal kernel stream for PM7 respin x64.
I recently tried a Low Latency kernel for attached music devices/synthesizers midi etc..and I'm having difficulty getting back to the normal kernel.
I've tried via the mint-updater kernel section and mismatch errors occur at 98%  :(
Any help would be greatly appreciated.
regards,
acer
« Last Edit: August 05, 2017, 07:40:13 am by acer »
Re: Kernel Update Help
« Reply #1 on: August 04, 2017, 10:01:02 am »
what's the output from:
dpkg -l | grep 4.4.0and
dpkg -l | grep linux-image
« Last Edit: August 04, 2017, 10:07:45 am by PCNetSpec »
Offline acer
« Reply #2 on: August 04, 2017, 10:45:59 am »
Output from
ii  linux-headers-4.4.0-87                 4.4.0-87.110                               all          Header files related to Linux kernel version 4.4.0
ii  linux-headers-4.4.0-87-generic         4.4.0-87.110                               amd64        Linux kernel headers for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-4.4.0-87-generic           4.4.0-87.110                               amd64        Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-4.4.0-87-lowlatency        4.4.0-87.110                               amd64        Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-extra-4.4.0-87-generic     4.4.0-87.110                               amd64        Linux kernel extra modules for version 4.4.0 on 64 bit x86 SMP
ii  linux-libc-dev:amd64                   4.4.0-89.112                               amd64        Linux Kernel Headers for development
ii  linux-signed-image-4.4.0-87-lowlatency 4.4.0-87.110                               amd64        Signed kernel image lowlatency
Output from
thanks
« Reply #3 on: August 04, 2017, 12:12:50 pm »
What is returned by:
sudo apt-get -s remove --purge linux-image-lowlatency linux-image-4.4.0-87-lowlatency linux-signed-image-4.4.0-87-lowlatencyand
sudo apt-get -s install linux-signed-image-genericand
[ -d /sys/firmware/efi ] && echo UEFI || echo BIOSThe first two commands won't actually remove or add anything, they're just a dry run to see what WOULD happen if we actually made the changes.
The last command is to see if Peppermint was installed in UEFI or Legacy BIOS mode.
And do you know how to boot into the generic kernel ?
« Last Edit: August 04, 2017, 12:15:51 pm by PCNetSpec »
Offline acer
« Reply #4 on: August 04, 2017, 12:34:39 pm »
ok mate the -s switch was a clue, cool!  ;)
Package 'linux-image-lowlatency' is not installed, so not removed
The following packages will be REMOVED
  linux-image-4.4.0-87-lowlatency* linux-signed-image-4.4.0-87-lowlatency*
0 to upgrade, 0 to newly install, 2 to remove and 0 not to upgrade.
Purg linux-signed-image-4.4.0-87-lowlatency [4.4.0-87.110]
Purg linux-image-4.4.0-87-lowlatency [4.4.0-87.110]
The following additional packages will be installed:
  linux-image-4.4.0-89-generic linux-image-extra-4.4.0-89-generic
  linux-signed-image-4.4.0-89-generic thermald
Suggested packages:
  fdutils linux-doc-4.4.0 | linux-source-4.4.0 linux-tools
  linux-headers-4.4.0-89-generic
The following NEW packages will be installed
  linux-signed-image-4.4.0-89-generic linux-signed-image-generic thermald
0 to upgrade, 5 to newly install, 0 to remove and 0 not to upgrade.
Inst linux-image-4.4.0-89-generic (4.4.0-89.112 Ubuntu:16.04/xenial-updates, Ubuntu:16.04/xenial-security [amd64])
Inst linux-image-extra-4.4.0-89-generic (4.4.0-89.112 Ubuntu:16.04/xenial-updates, Ubuntu:16.04/xenial-security [amd64])
Inst linux-signed-image-4.4.0-89-generic (4.4.0-89.112 Ubuntu:16.04/xenial-updates, Ubuntu:16.04/xenial-security [amd64])
Inst linux-signed-image-generic (4.4.0.89.95 Ubuntu:16.04/xenial-updates, Ubuntu:16.04/xenial-security [amd64])
Inst thermald (1.5-2ubuntu4 Ubuntu:16.04/xenial-updates [amd64])
Conf linux-image-4.4.0-89-generic (4.4.0-89.112 Ubuntu:16.04/xenial-updates, Ubuntu:16.04/xenial-security [amd64])
Conf linux-image-extra-4.4.0-89-generic (4.4.0-89.112 Ubuntu:16.04/xenial-updates, Ubuntu:16.04/xenial-security [amd64])
Conf linux-signed-image-4.4.0-89-generic (4.4.0-89.112 Ubuntu:16.04/xenial-updates, Ubuntu:16.04/xenial-security [amd64])
Conf linux-signed-image-generic (4.4.0.89.95 Ubuntu:16.04/xenial-updates, Ubuntu:16.04/xenial-security [amd64])
Conf thermald (1.5-2ubuntu4 Ubuntu:16.04/xenial-updates [amd64])
Nothing returned
Not using UEFI
Offline acer
« Reply #5 on: August 04, 2017, 12:38:39 pm »
sorry forgot to answer your last question.
No, I don't know how to boot into generic kernel  :-\
I only have one kernel in use according to the mint-updater 4.4.0-87
« Reply #6 on: August 04, 2017, 01:00:51 pm »
Okay first we're gonna have to make sure you can boot to the generic kernel .. because you need to be booted into this kernel to remove the lowlatency kernel.
So...
Shut down your PC
Power ON your PC, and as soon as the BIOS POST screen (manufacturer logo) disappears, hit and hold the "Shift" key .. you should be presented with the GRUB menu.
On the GRUB menu use the down arrow key to select "Advanced" .. and hit Enter.
Use the arrow key to select Peppermint GNU/Linux, with Linux 4.4.0-87-generic .. and hit Enter to boot that kernel.
Once you're at the desktop, run:
uname -aand post the output back here so I can see you got it right.
Offline acer
« Reply #7 on: August 04, 2017, 01:08:13 pm »
Linux HP-Notebook 4.4.0-87-generic #110-Ubuntu SMP Tue Jul 18 12:55:35 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Yeah done that before, just not in ages.
« Reply #8 on: August 04, 2017, 01:16:15 pm »
Cool .. okay, whilst booted to the generic kernel, run:
sudo apt-get remove --purge linux-image-4.4.0-87-lowlatency linux-signed-image-4.4.0-87-lowlatencythe reboot without doing anything in GRUB,
And post the output from:
uname -aagain
Offline acer
« Reply #9 on: August 04, 2017, 01:29:32 pm »
B I N G O ! Back to normal  :)
I should have remembered this, it's just been a hectic friday!
Will mark as solved..
Cheers PCNETSpec..enjoy your evening and good karma be with you.
« Reply #10 on: August 04, 2017, 01:30:55 pm »
Yep, all done...
You have a good evening too acer :)
Offline acer
Re: Kernel Update Help!
« Reply #11 on: August 05, 2017, 01:58:15 am »
Should I be concerned on the linux-libc-dev version?
Does it also need reverting back also or will that just change automajically with the next kernel update?
« Reply #12 on: August 05, 2017, 03:51:22 am »
No that's the right version.
I have the same version and I'm on the 4.10 kernel series .. in fact it's the only version in the repos ;)
« Last Edit: August 05, 2017, 03:57:05 am by PCNetSpec »
Offline acer
Re: Kernel Update Help! [Solved]
« Reply #13 on: August 05, 2017, 07:41:29 am »
Yeah sorry, realised this later than the post and forgot to update/remove post.
Thanks again for the confirmation  ;D
« Reply #14 on: August 05, 2017, 09:38:49 am »
No worries :)
