Author Topic: Saving passwords while using Chromium browser (SOLVED!)  (Read 4982 times)
Offline Scott
Re: Saving passwords while using Chromium browser
« Reply #15 on: July 03, 2014, 02:36:18 pm »
PCNetSpec/GClark
I did a test signing in/out of the Peppermint Forums with the Chromium password manager on P5/32 in virtualbox and it worked perfectly.
@GClark,
What extensions are you running? I'm running Adblock Plus and Keep My Opt-Outs.
In my test I disabled Adlock Plus on the Peppermint Forums website before making the first login where Chromium saved my information.
Whether Adblock Plus was enable or disabled made difference after that with logging in. The username/password was automatically entered correctly each time.
Have you tried Chromium with the Peppermint Forums website? Some sites are more challenging for password managers than others.
I've also changed some of my Chromium settings and if necessary I would be happy to compare those with your settings.
« Reply #16 on: July 03, 2014, 08:23:00 pm »
For what it's worth, I'm not a fan of Adblock Plus.  I never could get it to work right.
On the other hand, Adblock works perfectly for me.
Different companies -- Different products
Might want to give (simple) Adblock a whirl...   ;)
Offline gclark94560
    • GunBuilds.com
  • Peppermint version(s): 5
« Reply #17 on: July 04, 2014, 02:26:38 pm »
OK - it's all working now!!   8) 8)
I did ANOTHER install of PM5 and made sure Light locker was off and the password storage was enabled in Chromium..
AND IT WORKS THIS TIME!
Man plans, God laughs!
Offline rjm65
Re: Saving passwords while using Chromium browser (SOLVED!)
« Reply #18 on: July 04, 2014, 02:32:35 pm »
that light locker is more trouble then it is worth, they should remove it and go back to the old xscreensaver....
Robert
Peppermint 9 User
Gateway Solo 9300 Pro
IBM T40
Offline gclark94560
    • GunBuilds.com
« Reply #19 on: July 05, 2014, 04:37:56 pm »
Everyone - thanks for the help and support!
I'll master this thing yet!   :D
« Reply #20 on: July 06, 2014, 06:26:57 pm »
Light Locker actually seems good at what it does .. but it can catch you out if you're not aware of it ;)
