Author Topic: Searching this forum from any DuckDuckGo search box  (Read 2950 times)
« on: July 27, 2017, 01:25:45 pm »
Did you know this forum has a DuckDuckGo !bang ?
https://duckduckgo.com/bang
If you want to search this forum from any DuckDuckGo search box, just precede the search term with !pmos
So if you go to either our start page:
https://start.peppermintos.com
or the DDG start page:
or any other DDG search field .. then enter, for example:-
!pmos testand hit enter you will be forwarded to this forum and the search run here.
In fact it would be pretty easy to add this bang to the whiskermenu .. so you could run forum searches directly from the whiskermenu search box 8)
« Last Edit: July 27, 2017, 01:30:00 pm by PCNetSpec »
Re: Searching this forum from any DuckDuckGo search box
« Reply #1 on: July 27, 2017, 03:12:18 pm »
That's so cool  8).  I use bangs a lot.  They're one of the things that make DuckDuckGo a great search engine.  I didn't even think to try and find a Peppermint one.  You have to add this to the Whisker menu.  I can't think of any distro that has this facility  ;).
Offline cavy
  • Caveman
« Reply #2 on: July 27, 2017, 03:14:04 pm »
Thanks for pointing out this feature, we'll see if we can reap the benefits.  :D
« Reply #3 on: July 27, 2017, 03:37:42 pm »
Yep it'll be going in all future versions of Peppermint, but I can't add it retropsectively to current installs.
I can tell you how to manually add it though if you wish ?
Right click the "Menu" button and select:-
Properties > Search Action (tab)
click the "Add" button (+)
In the "Details" section add:-
Pattern: !pmos
Command: exo-open --launch WebBrowser https://forum.peppermintos.com/index.php?action=search2&search=%u
Click the "Close" button.
Now click the "Menu" button, and in the whiskermenu search field type
!pmos test
and hit enter.
« Last Edit: July 27, 2017, 04:37:16 pm by PCNetSpec »
Offline cavy
  • Caveman
« Reply #4 on: July 27, 2017, 03:42:51 pm »
Do you mean in a less than Ubuntu's approach with Amazon and Unity searches...?   ;)
« Reply #5 on: July 27, 2017, 04:01:55 pm »
This is VERY different to the Ubuntu Amazon lens.
All this does it send the search query to the forums search engine via a DDG search .. it sends ZERO search queries unless you specifically add the !pmos bang.
This is not a local search query that also sends that query to third parties, and it doesn't even go to DDG and this forum unless you specifically tell it to each time.
All this does is fire up your web browser and search the forum .. it couldn''t be more different that the Unity Amazon lens ::)
What you type into the whiskermenu search will NEVER go online unless you specifically tell it to pass the search to your web browser with the "!pmos" bang .. the whiskermenu search is NOT capable of going online itself, it just fires up your browser if and ONLY if you tell it to EACH TIME.
ZERO info will leave the whiskermenu search field unless you "accidentally" precede it with the !bang .. and there's little chance of that happening accidentally (besides which it shows you it's going to do it before you hit enter) .. it's as likely to happen accidentally as you accidentally opening your browser and running a search. Also remember this search is run ONLY on this forums search function, DDG only forward it .. and DDG are all about privacy anyway.
« Last Edit: July 27, 2017, 04:11:51 pm by PCNetSpec »
« Reply #6 on: July 27, 2017, 04:10:41 pm »
Cheers Mark, that works a treat  ;).  It's surprising how many people use DuckDuckGo without knowing about the Bangs.  It's such a cool feature.  The one I use the most is for Google images, !gi.
Offline cavy
  • Caveman
« Reply #7 on: July 27, 2017, 04:25:06 pm »
Okay Mark,  I choose to believe you. 100% blind faith, as I have chosen to with my motorcycle (wonder guru, Terry) mechanic, and Alan (bicycle) tech. On these tech matters. Though I'm disabled these days and wish I could.   :D
« Reply #8 on: July 27, 2017, 04:42:40 pm »
Actually I've now changed the whiskermenu command above .. now it doesn't even go via DDG it simply goes directly to this forums search engine.
Quote from: cavy
You may as well .. considering I have access to the update repos, if you don't feel you can trust me you REALLY shouldn't be using Peppermint because I can modify stuff on your system via updates, unless of course you never accept updates, or audit update code .. and even then you'd have to trust I'd not added some 'nasty' to the original ISO ;)
« Last Edit: July 27, 2017, 04:49:46 pm by PCNetSpec »
Offline cavy
  • Caveman
« Reply #9 on: July 27, 2017, 05:00:44 pm »
It was a COMPLIMENT you xxxxtard.....!   ;D
Do you really think I would still hanging about, if I did not believe in PMOS. Plus paid money into the DONATION account of Peppermint.   ;)
Mark, err, m8, ..... rant over....!
« Reply #10 on: July 27, 2017, 05:05:18 pm »
Don't get your knickers in a twist :))
(did you not notice the wink)
But remember this is on a PUBLIC board .. so your comment left me little choice but to explain.
« Last Edit: July 27, 2017, 05:08:23 pm by PCNetSpec »
Offline cavy
  • Caveman
« Reply #11 on: July 27, 2017, 05:10:34 pm »
Okay, nickers are in bristol and shipshape fashion. lol  ;)
« Reply #12 on: July 27, 2017, 05:25:42 pm »
That does beg the question - what exactly were you doing in Bristol that caused you to leave without them ?
Offline cavy
  • Caveman
« Reply #13 on: July 27, 2017, 05:39:32 pm »
You are really are taking the *iss m8. Knowing this is AN English (non American) expression.  LOL.....!
