Author Topic: Very slow WiFi connection (SOLVED)  (Read 3534 times)
Offline alek
Re: Very slow WiFi connection
« Reply #15 on: July 23, 2017, 05:18:19 pm »
For now, wifi doesnt work. So I will try to redo what I did before and do the commands you pasted. I will do it tomorrow morning though
« Reply #16 on: July 23, 2017, 05:19:27 pm »
Okey dokey .. catch you tomorrow then.
Offline alek
« Reply #17 on: July 24, 2017, 03:32:55 am »
So i tried to connect to the internet via ethernet cable attached to router. The laptop doesnt see anything. I mean it doesnt have internet connection via ethernet nor doesnt see wifi. I tried opening browsers but they wont open now. If I type lshw, it says that there is no such command. I didn't type any extra commands, just the one you advised... So now it doesnt even seem like I can reverse it back to where I was....
Offline alek
« Reply #18 on: July 24, 2017, 03:39:34 am »
For whatever reasons laptop turns off in half an hour now, something is surely wrong with the laptop right now. It used to turn off in 15 secs and now it seems like forever
Offline alek
« Reply #19 on: July 24, 2017, 09:18:10 am »
I looked through forums to find possible solutions but it seems like there is no way to reverse it back where I was before in the terminal because laptop doesnt see neither wifi nor ethernet cable. So is there a way to either manually find files that have been installed and delete them? If not, would reinstalling Linux help?(at least to get back where it was before, or there were changes in the system?)
« Reply #20 on: July 24, 2017, 03:43:30 pm »
the wl driver **could** be installed manually, but it's not straight forward.
If the cabled connection is also kaput I'd be more likely to simply reinstall, because it sounds like a bigger problem than just the wireless drivers.
If this isn't a dual boot setup, I'd just reinstall .. then install the wl drivers by following this post:
https://forum.peppermintos.com/index.php/topic,5870.msg59248.html#msg59248
Offline alek
« Reply #21 on: July 24, 2017, 05:31:00 pm »
Okay, so I reinstalled linux, did the command you suggested and here is an output:
WARNING: you should run this program as super-user.
  *-network
       product: BCM4313 802.11bgn Wireless Network Adapter
       vendor: Broadcom Corporation
       physical id: 0
       bus info: pci@0000:03:00.0
       logical name: wlp3s0
       version: 01
       serial: c0:14:3d:da:a0:43
       width: 64 bits
       clock: 33MHz
       capabilities: bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=wl0 driverversion=6.30.223.271 (r587334) ip=192.168.1.50 latency=0 multicast=yes wireless=IEEE 802.11
       resources: irq:17 memory:eb500000-eb503fff
  *-network
       physical id: 0
       bus info: pci@0000:04:00.0
       logical name: enp4s0
       version: 07
       serial: 3c:97:0e:34:e5:c4
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8168e-3_0.0.4 03/27/12 ip=192.168.1.91 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
       resources: irq:27 ioport:2000(size=256) memory:eb404000-eb404fff memory:eb400000-eb403fff
WARNING: output may be incomplete or inaccurate, you should run this program as super-user.
So what would be my next steps?
Offline alek
« Reply #22 on: July 24, 2017, 05:34:54 pm »
Here is the output as a superuser
*-network
       physical id: 0
       version: 01
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
  *-network
       physical id: 0
       version: 07
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
Offline alek
« Reply #23 on: July 24, 2017, 06:00:01 pm »
As for now, I am not really sure what happened (I guess it proves that I am really novice-noob in linux), but somehow Wi-Fi works fine. I am not still sure if it's temporary of commands above really helped... So I am just waiting for you to answer...
« Reply #24 on: July 24, 2017, 06:19:43 pm »
You're done :) .. you replaced the default bcma-pci-bridge driver with the wl driver which is better for your card.
Offline alek
« Reply #25 on: July 24, 2017, 06:24:20 pm »
Oh, that makes sense. Hopefully, I will never face this problem ever again. Thank you a lot for your help  :)
P.S. I am not really sure how to set this topic as SOLVED.
« Last Edit: July 24, 2017, 06:26:23 pm by alek »
« Reply #26 on: July 24, 2017, 06:38:47 pm »
To mark the topic as (SOLVED), please edit the FIRST posting in this topic, and change:-
Subject: Very slow WiFi connection (SOLVED)
TIA :)
