Author Topic: (SOLVED) how to put my picture on user login?  (Read 1684 times)
Offline penrose1950
« on: July 01, 2014, 08:11:22 am »
hello could some one please tell me how i can use my picture where the blank picture is at login,on some distros it is under about me but i cannot see this in 5
thank you..
« Last Edit: July 02, 2014, 03:49:28 am by penrose1950 »
Re: how to put my picture on user login?
« Reply #1 on: July 01, 2014, 08:24:21 am »
Place an image (.jpg or .png of around 90x90 but doesn't have to be exact) in your home folder .. then rename it to
.face
no extension, and YES it must start with a "." .. so be aware, after renaming it, it will be hidden unless you have "Show Hidden" enabled in your file manager (Ctrl+H toggles "Show Hidden")
At least I'm "pretty" sure it can be a JPG .. I know PNG's work as that's what I use.
« Last Edit: July 01, 2014, 08:26:37 am by PCNetSpec »
Offline penrose1950
« Reply #2 on: July 02, 2014, 03:47:53 am »
ok thank you.
