Author Topic: Using arrow keys as keyboard shortcuts?  (Read 1137 times)
Offline zeppelin0110
« on: July 20, 2017, 08:15:25 pm »
Hi all,
I would like to emulate a few windows shortcuts I'm very fond of. One of them is Super+UP arrow. This would maximize the active window.  However, it's just not working. I verified in 'Keyboard shortcuts' tab of Peppermint Control Center that the Super key is working just fine. For example, Super+n works just fine for maximizing. I then just typed in 'Up' in the input field, since pressing the arrow key causes input to shift to the next control in the form. But this did not work. Please advise!
Offline josephd
  • Peppermint OS Website Admin
    • LinuxBookPro
Re: Using arrow keys as keyboard shortcuts?
« Reply #1 on: July 21, 2017, 07:00:02 am »
Alt+F10 will do that by default.
I couldn't figure it out either. The keyboard shortcuts pane doesn't seem to support key codes.
Perhaps somone knows a terminal command to set shortcuts?
« Reply #2 on: July 21, 2017, 08:03:29 am »
Hi zeppelin0110,
The following does indeed not work!!  :-[ See my corrected instructions after the crossed out text!
It is easy to accomplish : in the Keyboard Shortcuts tab of the Peppermint Control Center  click on the Add New button, then enter the command you wish to have executed (e.g. maximize_window_key, which you can see in the list of already set shortcuts is currently assigned to the shortcut <Alt>F10), then in the next window that opens click on the the button Super and then type Up in the text box and click on the Apply button.
I'm not sure why this is not working for you.
Open the Keyboard Shortcuts tab of the Peppermint Control Center. Scroll down to the Window Manager Shortcuts section (lower part of the list of shortcuts). Look for the entry in the Action column that reads maximize_window_key and make a double click on it. A window with the title Assign New Shortcut will appear. Here you can now click on the button Super and then in the text box enter the text Up. Then click on the Apply button. Now pressing the shortcut <Super><Up-arrow-key> will maximize the active window.  ;)
Sorry for the error.  ::)
« Last Edit: July 21, 2017, 09:02:10 am by Slim.Fatz »
« Reply #3 on: July 21, 2017, 11:12:17 am »
I'll try this out later today and will report on the results.
« Reply #4 on: July 21, 2017, 07:43:59 pm »
Regrettably, I couldn't get it work just yet. This what the keyboard shortcuts editor looks like:
Also, the contents of ~/.config/xfce4/xfconf/xfce-perchannel-xml/xfce4-keyboard-shortcuts.xml:
<?xml version="1.0" encoding="UTF-8"?>
<channel name="xfce4-keyboard-shortcuts" version="1.0">
  <property name="commands" type="empty">
    <property name="default" type="empty">
      <property name="&lt;Alt&gt;F1" type="empty"/>
      <property name="&lt;Alt&gt;F2" type="empty">
        <property name="startup-notify" type="empty"/>
      </property>
      <property name="&lt;Alt&gt;F3" type="empty">
      </property>
      <property name="&lt;Primary&gt;&lt;Alt&gt;Delete" type="empty"/>
      <property name="XF86Display" type="empty"/>
      <property name="&lt;Super&gt;p" type="empty"/>
      <property name="&lt;Primary&gt;Escape" type="empty"/>
      <property name="XF86WWW" type="empty"/>
      <property name="XF86Mail" type="empty"/>
    </property>
    <property name="custom" type="empty">
      <property name="override" type="bool" value="true"/>
    </property>
  </property>
  <property name="xfwm4" type="empty">
      <property name="&lt;Alt&gt;Insert" type="empty"/>
      <property name="Escape" type="empty"/>
      <property name="Left" type="empty"/>
      <property name="Right" type="empty"/>
      <property name="Up" type="empty"/>
      <property name="Down" type="empty"/>
      <property name="&lt;Alt&gt;Tab" type="empty"/>
      <property name="&lt;Alt&gt;&lt;Shift&gt;Tab" type="empty"/>
      <property name="&lt;Alt&gt;Delete" type="empty"/>
      <property name="&lt;Control&gt;&lt;Alt&gt;Down" type="empty"/>
      <property name="&lt;Control&gt;&lt;Alt&gt;Left" type="empty"/>
      <property name="&lt;Shift&gt;&lt;Alt&gt;Page_Down" type="empty"/>
      <property name="&lt;Alt&gt;F4" type="empty"/>
      <property name="&lt;Alt&gt;F6" type="empty"/>
      <property name="&lt;Alt&gt;F7" type="empty"/>
      <property name="&lt;Alt&gt;F8" type="empty"/>
      <property name="&lt;Alt&gt;F9" type="empty"/>
      <property name="&lt;Alt&gt;F10" type="empty"/>
      <property name="&lt;Alt&gt;F11" type="empty"/>
      <property name="&lt;Alt&gt;F12" type="empty"/>
      <property name="&lt;Control&gt;&lt;Shift&gt;&lt;Alt&gt;Left" type="empty"/>
      <property name="&lt;Alt&gt;&lt;Control&gt;End" type="empty"/>
      <property name="&lt;Alt&gt;&lt;Control&gt;Home" type="empty"/>
      <property name="&lt;Control&gt;&lt;Shift&gt;&lt;Alt&gt;Right" type="empty"/>
      <property name="&lt;Control&gt;&lt;Shift&gt;&lt;Alt&gt;Up" type="empty"/>
      <property name="&lt;Alt&gt;&lt;Control&gt;KP_1" type="empty"/>
      <property name="&lt;Alt&gt;&lt;Control&gt;KP_2" type="empty"/>
      <property name="&lt;Alt&gt;&lt;Control&gt;KP_3" type="empty"/>
      <property name="&lt;Alt&gt;&lt;Control&gt;KP_4" type="empty"/>
      <property name="&lt;Alt&gt;&lt;Control&gt;KP_5" type="empty"/>
      <property name="&lt;Alt&gt;&lt;Control&gt;KP_6" type="empty"/>
      <property name="&lt;Alt&gt;&lt;Control&gt;KP_7" type="empty"/>
      <property name="&lt;Alt&gt;&lt;Control&gt;KP_8" type="empty"/>
      <property name="&lt;Alt&gt;&lt;Control&gt;KP_9" type="empty"/>
      <property name="&lt;Alt&gt;space" type="empty"/>
      <property name="&lt;Shift&gt;&lt;Alt&gt;Page_Up" type="empty"/>
      <property name="&lt;Control&gt;&lt;Alt&gt;Right" type="empty"/>
      <property name="&lt;Control&gt;&lt;Alt&gt;d" type="empty"/>
      <property name="&lt;Control&gt;&lt;Alt&gt;Up" type="empty"/>
      <property name="&lt;Super&gt;Tab" type="empty"/>
      <property name="&lt;Control&gt;F1" type="empty"/>
      <property name="&lt;Control&gt;F2" type="empty"/>
      <property name="&lt;Control&gt;F3" type="empty"/>
      <property name="&lt;Control&gt;F4" type="empty"/>
      <property name="&lt;Control&gt;F5" type="empty"/>
      <property name="&lt;Control&gt;F6" type="empty"/>
      <property name="&lt;Control&gt;F7" type="empty"/>
      <property name="&lt;Control&gt;F8" type="empty"/>
      <property name="&lt;Control&gt;F9" type="empty"/>
      <property name="&lt;Control&gt;F10" type="empty"/>
      <property name="&lt;Control&gt;F11" type="empty"/>
      <property name="&lt;Control&gt;F12" type="empty"/>
    </property>
      <property name="&lt;Control&gt;F4" type="string" value="workspace_4_key"/>
      <property name="&lt;Control&gt;F5" type="string" value="workspace_5_key"/>
      <property name="&lt;Control&gt;F6" type="string" value="workspace_6_key"/>
      <property name="&lt;Control&gt;F7" type="string" value="workspace_7_key"/>
      <property name="&lt;Control&gt;F8" type="string" value="workspace_8_key"/>
      <property name="&lt;Control&gt;F9" type="string" value="workspace_9_key"/>
      <property name="&lt;Alt&gt;Tab" type="string" value="cycle_windows_key"/>
      <property name="&lt;Control&gt;&lt;Alt&gt;Right" type="string" value="right_workspace_key"/>
      <property name="Left" type="string" value="left_key"/>
      <property name="&lt;Control&gt;&lt;Shift&gt;&lt;Alt&gt;Left" type="string" value="move_window_left_key"/>
      <property name="&lt;Control&gt;&lt;Shift&gt;&lt;Alt&gt;Right" type="string" value="move_window_right_key"/>
      <property name="Up" type="string" value="up_key"/>
      <property name="&lt;Alt&gt;F4" type="string" value="close_window_key"/>
      <property name="&lt;Alt&gt;F6" type="string" value="stick_window_key"/>
      <property name="&lt;Control&gt;&lt;Alt&gt;Down" type="string" value="down_workspace_key"/>
      <property name="&lt;Alt&gt;F7" type="string" value="move_window_key"/>
      <property name="&lt;Alt&gt;F9" type="string" value="hide_window_key"/>
      <property name="&lt;Alt&gt;F11" type="string" value="fullscreen_key"/>
      <property name="&lt;Alt&gt;F8" type="string" value="resize_window_key"/>
      <property name="&lt;Super&gt;Tab" type="string" value="switch_window_key"/>
      <property name="Escape" type="string" value="cancel_key"/>
      <property name="&lt;Alt&gt;&lt;Control&gt;KP_1" type="string" value="move_window_workspace_1_key"/>
      <property name="&lt;Alt&gt;&lt;Control&gt;KP_2" type="string" value="move_window_workspace_2_key"/>
      <property name="&lt;Alt&gt;&lt;Control&gt;KP_3" type="string" value="move_window_workspace_3_key"/>
      <property name="&lt;Alt&gt;&lt;Control&gt;KP_4" type="string" value="move_window_workspace_4_key"/>
      <property name="&lt;Alt&gt;&lt;Control&gt;KP_5" type="string" value="move_window_workspace_5_key"/>
      <property name="&lt;Alt&gt;&lt;Control&gt;KP_6" type="string" value="move_window_workspace_6_key"/>
      <property name="Down" type="string" value="down_key"/>
      <property name="&lt;Control&gt;&lt;Shift&gt;&lt;Alt&gt;Up" type="string" value="move_window_up_key"/>
      <property name="&lt;Shift&gt;&lt;Alt&gt;Page_Down" type="string" value="lower_window_key"/>
      <property name="&lt;Alt&gt;F12" type="string" value="above_key"/>
      <property name="&lt;Alt&gt;&lt;Control&gt;KP_8" type="string" value="move_window_workspace_8_key"/>
      <property name="&lt;Alt&gt;&lt;Control&gt;KP_9" type="string" value="move_window_workspace_9_key"/>
      <property name="Right" type="string" value="right_key"/>
      <property name="&lt;Control&gt;&lt;Alt&gt;Up" type="string" value="up_workspace_key"/>
      <property name="&lt;Control&gt;F10" type="string" value="workspace_10_key"/>
      <property name="&lt;Alt&gt;&lt;Control&gt;KP_7" type="string" value="move_window_workspace_7_key"/>
      <property name="&lt;Alt&gt;&lt;Control&gt;End" type="string" value="move_window_next_workspace_key"/>
      <property name="&lt;Alt&gt;Delete" type="string" value="del_workspace_key"/>
      <property name="&lt;Control&gt;&lt;Alt&gt;Left" type="string" value="left_workspace_key"/>
      <property name="&lt;Control&gt;F12" type="string" value="workspace_12_key"/>
      <property name="&lt;Alt&gt;space" type="string" value="popup_menu_key"/>
      <property name="&lt;Alt&gt;&lt;Shift&gt;Tab" type="string" value="cycle_reverse_windows_key"/>
      <property name="&lt;Shift&gt;&lt;Alt&gt;Page_Up" type="string" value="raise_window_key"/>
      <property name="&lt;Alt&gt;Insert" type="string" value="add_workspace_key"/>
      <property name="&lt;Alt&gt;&lt;Control&gt;Home" type="string" value="move_window_prev_workspace_key"/>
      <property name="&lt;Control&gt;F2" type="string" value="workspace_2_key"/>
      <property name="&lt;Control&gt;F1" type="string" value="workspace_1_key"/>
      <property name="&lt;Control&gt;F11" type="string" value="workspace_11_key"/>
      <property name="&lt;Primary&gt;&lt;Alt&gt;d" type="string" value="show_desktop_key"/>
      <property name="&lt;Super&gt;Up" type="string" value="maximize_window_key"/>
    </property>
  </property>
  <property name="providers" type="array">
    <value type="string" value="xfwm4"/>
    <value type="string" value="commands"/>
  </property>
</channel>
I wonder if it's my laptop's hardware at fault here. It's a pretty basic one - lenovo ideapad 110.
