Author Topic: Touch pad on old laptop - how to disable [solved]  (Read 1010 times)
Offline Sprinterdriver
  • Peppermint version(s): 8-20170527-i386
« on: July 19, 2017, 07:05:28 pm »
Hi.
I just installed Peppermint 8 on a old Acer Travelmate 634LC.
Back when It was running winxp (preinstalled from factory) the touch-pad could easily be toggled on/off by Fn+F7.
When I do that (Fn+F7) in Peppermint, it seems to be working - but just seconds later, the touchpad enables itself (after 2-4 seconds delay) and after that the Fn+F7 keyboard combo will have no effect.
I was looking for mouse options, but couldn't find any. Is there any way to disable touch pad on this computer?
Thanks
« Last Edit: July 20, 2017, 01:00:58 pm by Sprinterdriver »
Re: Touch pad on old laptop - how to disable
« Reply #1 on: July 19, 2017, 07:10:40 pm »
First of all, make sure your system is FULLY updated.
Then go to:-
Menu > Preferences > Peppermint Control Center > Keyboard & Pointer (tab)
and remove the tick from:
"Touchpad Enabled"
« Reply #2 on: July 20, 2017, 01:00:22 pm »
Thanks a lot  :)
Solved  :D
