Author Topic: Anyone been able to install ToonTown Rewritten on Peppermint?  (Read 1079 times)
Offline PaulWxford
Has anyone been able to install ToonTown Rewritten on Peppermint?
I can successfully do it on Linux Mint but I am trying to install it on an older laptop and chose to try out Peppermint because of the great reviews and it being an ideal light OS for the older laptop.
I have tried both ways, using Wine and doing the Linux download options and bouth fail to properly launch correctly.
Re: Anyone been able to install ToonTown Rewritten on Peppermint?
« Reply #1 on: July 14, 2017, 09:00:19 am »
Which version of Mint ?
« Reply #2 on: July 14, 2017, 10:40:54 am »
Seems there's a known issue with their Launcher crashing in 16.04 and apparently they're in no hurry to fix.
https://ttrforums.com/threads/linux-launcher-crashing.13709/
But there is a custom launcher called ShtickerBook Rewritten that launches ToonTown Rewtitten that works
You can download the shticker-book-rewritten_1.2.0_amd64.deb file from there:
http://download.opensuse.org/repositories/home:/madsciencecoder:/shticker-book-rewritten/xUbuntu_16.04/amd64/
or directly from this link:
http://download.opensuse.org/repositories/home:/madsciencecoder:/shticker-book-rewritten/xUbuntu_16.04/amd64/shticker-book-rewritten_1.2.0_amd64.deb
then just double-click it to install.
You'll then find it in the menu at
Menu > Games > ShtickerBook Rewritten
I just tested it and it worked perfectly :)
« Last Edit: July 14, 2017, 10:44:23 am by PCNetSpec »
