Author Topic: Possible causes for system hang with cursor and sound functional (SOLVED)  (Read 684 times)
Offline markba633csi
  • Peppermint version(s): 6.0
Experiencing occasional system freezes when playing YouTube videos (Peppermint 6, Thinkpad T400/ 2.4ghz/4G ram, integrated Intel graphics) with sound continuing and cursor still moving.   Does not occur when playing DVDs.
Am I running out of ram or swap space?  Any way to tell if this is a hardware or software issue?  Some type of formatting problem with YouTube itself?
I read something to the effect that the kernel should be using GPET (precision event timer) and that this is configurable in GRUB.  Not something I'm wanting to mess with at this point.
This seems to be a frequently reported problem with other operating systems and platforms as well,  which leads me to believe it is a system timing issue.
Ideas?
Mark S.
« Last Edit: July 08, 2017, 01:45:43 pm by markba633csi »
Offline cavy
  • Caveman
Re: Possible causes for system hang with cursor and sound functional
« Reply #1 on: July 07, 2017, 06:05:04 pm »
Hi Mark S
Please refer to this post and adjust your swap values (and Cache Pressure to 50) from 60 to 1. https://forum.peppermintos.com/index.php/topic,5464.0.html
Especially if you experience loose of picture or blank screen while playing a you tube video.
cavy  :D
« Last Edit: July 07, 2017, 06:09:32 pm by cavy »
« Reply #2 on: July 08, 2017, 01:45:11 pm »
Thanks Cavy that's a big list- I'm sure the fix is in there so I'm going to mark it SOLVED for now.
Mark
