Author Topic: Need help with Arduino install (SOLVED)  (Read 784 times)
Offline markba633csi
  • Peppermint version(s): 6.0
« on: July 06, 2017, 05:00:18 pm »
Need to extract Arduino file to usr/local so it can talk to the com ports (Arduino program will run from desktop but won't connect to ports)
I get a "permission denied" message
The filename is arduino-1.8.3-linux32.tar.xz
Mark S.
Peppermint 6
« Last Edit: July 07, 2017, 08:14:45 pm by markba633csi »
Re: Need help with Arduino install
« Reply #1 on: July 06, 2017, 05:17:39 pm »
Run:
gksudo nemo /usr/local
copy the arduino-1.8.3-linux32.tar.xz file into the file manager window that just opened .. then right-click it and select "Extract Here".
« Reply #2 on: July 07, 2017, 08:14:09 pm »
Thanks Mark seems to work, marking as Solved
MS
