Author Topic: uninstall problems  (Read 1721 times)
Offline 2017expre
  • Scandinavian man
uninstall problems
« on: June 22, 2017, 06:34:33 am »
i tested this windows wine emulator whatever
find not useful
then i remove, and it shows not installed
but it is there .. i can open it from menu ??
and same time it should not be installed ?
home/i_t/.local/share/wineprefixes/firefox/dosdevices/c:/Program Files (x86)/Mozilla Firefox
well i then noticed need delete about 10 different wine..starting applications from program list (but needed just 1 to install all that?)
what was left, is wine in menu and there is old version of windows working mozilla firefox
what is best way to get rid of this wine _ and firefox under that in menu?
can i go to just address of wine in program list or should some uninstall tool?
« Last Edit: June 22, 2017, 06:57:40 am by 2017expre »
Re: uninstall problems
« Reply #1 on: June 22, 2017, 07:21:33 am »
Fully removing WINE is always a pain.
Can you run:
sudo updatedb
then post the output from:
dpkg -l | grep -i wine
locate -i wine
Offline 2017expre
  • Scandinavian man
« Reply #2 on: June 22, 2017, 07:30:06 am »
Can you run:
sudo updatedb
i_t@i ~ $ dpkg -l | grep -i wine
rc  wine1.6                                1:1.6.2-0ubuntu14                               amd64        Microsoft Windows Compatibility Layer (Binary Emulator and Library)
locate -i wine
yes i used all those 3
there comes huge list of stuff, they could be deleted some way?
« Last Edit: June 22, 2017, 07:34:55 am by 2017expre »
« Reply #3 on: June 22, 2017, 08:18:03 am »
It'll be hard to give specific instructions unless you post the output ;)
If the output is large, maybe post it to pastebin
https://pastebin.com
and post a link to it.
Offline 2017expre
  • Scandinavian man
« Reply #4 on: June 22, 2017, 08:48:20 am »
<iframe src="https://pastebin.com/embed_iframe/2yM4BLNz" style="border:none;width:100%"></iframe>
https://pastebin.com/2yM4BLNz
Here other link may be better, there was limit 30k something so i used pastebin.
Thanks if you can help how to delete those.
« Last Edit: June 22, 2017, 08:49:57 am by 2017expre »
« Reply #5 on: June 22, 2017, 11:20:56 am »
Okay if you want to get rid of everything to do with WINE, lets' start here .. open a terminal and run these commands in sequence
cd ~
sudo rm -rf .wine
once that's done, run:
sudo updatedb
locate -i wine
again
Offline 2017expre
  • Scandinavian man
« Reply #6 on: June 22, 2017, 11:30:18 am »
cd ~
sudo rm -rf .wine
sudo updatedb
locate -i wine
again
Thanks, well i copied there https://pastebin.com/wy9SpDBA
« Reply #7 on: June 22, 2017, 02:12:13 pm »
Okay run these in sequence
cd ~/.local/share
sudo rm -rf wineprefixes
now run:
sudo updatedb
and post the output from
locate -i wine
again.
Offline 2017expre
  • Scandinavian man
« Reply #8 on: June 22, 2017, 03:28:38 pm »
cd ~/.local/share
now run:
sudo updatedb
locate -i wine
again.
Theres 3rd part https://pastebin.com/0KKCvXMY
« Reply #9 on: June 22, 2017, 08:32:02 pm »
okay run these commands in sequence:
sudo rm -v /etc/xdg/menus/applications-merged/wine.menu
rm -rv /home/i_t/.cache/winetricks
rm -v /home/i_t/.config/menus/applications-merged/wine-Programs-Mozilla Firefox.menu
rm -v /home/i_t/.local/share/applications/wine-extension*.desktop
rm -v /home/i_t/.local/share/desktop-directories/wine*.directory
sudo apt-get remove --purge wine1.6
then run:
sudo updatedb
and post the output from:
locate -i wine
again
Offline 2017expre
  • Scandinavian man
« Reply #10 on: June 23, 2017, 02:45:07 am »
Here was answer: no such file or directory
then run:
sudo updatedb
locate -i wine
again
Thanks, ok i got put those. Some informed , no such file or directory though.
Here is next output: https://pastebin.com/HdUYBLJD
(disappeared already from menu, so gone forward)
« Last Edit: June 23, 2017, 04:59:37 am by 2017expre »
« Reply #11 on: June 23, 2017, 11:17:43 am »
The only 2 left are
rm -rv /home/i_t/.local/share/applications/wine
but they're not really important.
Offline 2017expre
  • Scandinavian man
« Reply #12 on: June 23, 2017, 11:29:20 am »
The only 2 left are
Thanks, first went ok, removed somethings but 2nd under : "rm: cannot remove '/home/i_t/.config/menus/applications-merged/wine-Programs-Mozilla': No such file or directory
rm: cannot remove 'Firefox.menu': No such file or directory
Well good to delete what not use. Other alternative would be to install whole thing again and start from beginning ..
« Reply #13 on: June 23, 2017, 11:32:28 am »
I wouldn't worry about that file.
Offline 2017expre
  • Scandinavian man
« Reply #14 on: June 23, 2017, 12:11:52 pm »
Well , noticed i could check (w right mouse button menu) show hidden files
then go config / menus / .. and there was this listed as "no such file or directory" .. i deleted from there though lightweight case it seemed.
Theres nothing in menu anymore, so quite well should those wine and old version of windows compatible firefox now gone deleted.
« Last Edit: June 23, 2017, 12:14:27 pm by 2017expre »
