Author Topic: (Hd or others too) video not show well full screen  (Read 2221 times)
Offline 2017expre
  • Scandinavian man
Re: (Hd or others too) video not show well full screen
« Reply #15 on: June 22, 2017, 08:03:25 am »
what i last tried:
additional drivers
this device is using alternative driver
using processor microcode firmware for amd cpu's from amd64-microcode (proprietary)
..before that it was in setting: do not use device
and there was text, this device is not working
so not working, means: better not use ?
but i dont know if this helps at all when there might be problem in graphics card ? seems difference but i see if any help or not, then change back if more problems seems
« Reply #16 on: June 22, 2017, 09:56:24 am »
Is this "waving" the same thing as "screen tearing" (do a forum search for that)?
I've done the search for you this time:
https://forum.peppermintos.com/index.php/topic,5633.msg56530.html#msg56530
Offline 2017expre
  • Scandinavian man
« Reply #17 on: June 22, 2017, 12:22:26 pm »
Thanks a lot. Well i put in those lines for Amd and reboot.
Then check again ..well i think problem is not solved but actually this when picture tears, or kind of shakes when moving happens,
not too bad problem.
I have also read thing like it would be good idea to uninstall previous drivers for graphic card and then quality would be everywhere sometime
more low but would get better when install again new updated drivers.. ?
Quite small problems. I before this watched john wick 2 and made other tests , changed vga cable instead of hdmi, made no difference to sideways shaking (tearing) thing. Also i have test sound, i use headphones. There is no problems at all been but just find right volume levels.
Let me know if there is more procedures i can check, 100% fix would not be bad at all.
