Author Topic: How to solve Peppermint 8 can tweak internet connection be more fast  (Read 1803 times)
Offline Gadinked
  • Gadinked Board
    • Pitabisnis
I just started install Peppermint version 8 on my below hardware.
System:    Host: ping-m Kernel: 4.10.0-22-generic i686 (32 bit) Desktop: N/A
           Distro: Peppermint Eight
Machine:   System: TOSHIBA product: TOSHIBA NB200 v: PLL20L-00L002
           Mobo: TOSHIBA model: KAVAA v: 1.00
           Bios: TOSHIBA v: V1.20 date: 04/07/2009
CPU:       Single core Intel Atom N280 (-HT-) cache: 512 KB
           clock speeds: max: 1667 MHz 1: 1000 MHz 2: 1667 MHz
Graphics:  Card: Intel Mobile 945GSE Express Integrated Graphics Controller
           Display Server: X.Org 1.18.4 drivers: intel (unloaded: fbdev,vesa)
           Resolution: 1024x600@60.00hz
           GLX Renderer: Mesa DRI Intel 945GME x86/MMX/SSE2
           GLX Version: 1.4 Mesa 17.0.2
Audio:     Card Intel NM10/ICH7 Family High Definition Audio Controller
           Sound: Advanced Linux Sound Architecture v: k4.10.0-22-generic
Network:   Card-1: Qualcomm Atheros AR9285 Wireless Network Adapter (PCI-Express)
           driver: ath9k
           Card-2: Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
           driver: r8169
           IF: enp4s0 state: down mac: <filter>
Drives:    HDD Total Size: 160.0GB (3.9% used)
           ID-1: /dev/sda model: TOSHIBA_MK1655GS size: 160.0GB
Partition: ID-1: / size: 146G used: 5.0G (4%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 1.06GB used: 0.49GB (46%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 52.0C mobo: N/A
Info:      Processes: 185 Uptime: 1:03 Memory: 464.2/989.2MB
I wonder with Peppermint Performance, before i try Fedora 25 LXDE i686 on my mechine but i am upset with have event lag. so i jump to this distro.
My question are :
1. How to make Peppermint 8 can fast in surf the internet (browsing).
2. I think i got slow response when i click on menu libre, how to solve it.
3. Can Peppermint use for development work with my specify mechine?.
I need more detail explain for my question, if any people can answer it, i say thanks a lot of.
« Last Edit: June 18, 2017, 04:47:00 pm by AndyInMokum »
You could try disabling IPv6 by right-clicking the connection icon in the lower right-hand corner of the screen, then Edit connections, selecting your connection and clicking Edit. In the IPv6 tab set the drop-down menu to Ignore.
It would be even better to set the IPv4 tab to Automatic (DHCP) addresses only, but then you'll need to specify DNS servers below.
« Last Edit: June 18, 2017, 05:22:54 pm by murraymint »
1) Can you define "slow internet browsing" ? .. what is slow and when ?
2) It is NOT a good idea to use MenuLibre in Peppermint (or any other LXDE distro) .. there's a VERY good chance it will screw up your menus .. there is no 100% safe GUI menu editor for LXDE.
3) Define "Development work" ? .. if you mean coding, sure any spec machine can be used, if however it includes testing the code, and say that code is a game then you'd need a high spec machine .. so this question is impossible to answer unless you tell us what it's to be used for.
« Last Edit: June 18, 2017, 06:58:55 pm by PCNetSpec »
