Author Topic: Desktop is not showing anything.  (Read 8076 times)
Re: Desktop is not showing anything.
« Reply #45 on: June 27, 2017, 06:03:29 am »
On mine it says nemo -n (Peppermint 7).
Offline abhaymaniyar
« Reply #46 on: June 27, 2017, 11:34:57 am »
Ok! I have changed it to that command now. It doesn't seem to be working.
« Reply #47 on: June 28, 2017, 09:55:26 am »
Can you pastebin the contents of
pluma /etc/xdg/lxsession/Peppermint/desktop.confand
pluma ~/.config/lxsession/Peppermint/desktop.conf
« Reply #48 on: June 30, 2017, 05:57:57 am »
This is the output for first command:
https://pastebin.com/xY0NNLv3
This is the output for second command:
https://pastebin.com/izDdJT65
« Reply #49 on: June 30, 2017, 10:45:36 am »
Run:
mv -v ~/.config/lxsession/Peppermint/desktop.conf pluma ~/.config/lxsession/desktop.conf.brokenthen log off/on.
Any difference ?
I'm not expecting this to work, but it should set the lxsession back to defaults .. to at least rule that out..
« Reply #50 on: July 01, 2017, 03:13:28 am »
Run:
Any difference ?
This command is returning this output:
mv: target '/home/abhay/.config/lxsession/desktop.conf.broken' is not a directory
But I moved the "desktop.conf" file to its parent directory and renamed it manually. It changed whole theme and icons to its default peppermint settings but desktop still not responsive.
« Last Edit: July 01, 2017, 03:24:03 am by abhaymaniyar »
« Reply #51 on: July 01, 2017, 06:40:15 am »
Okay not that then .. you can move it back again if you want.
Something else is obviously still grabbing control of the desktop away from nemo.
Can you do this again, after a reboot.
ps aux >> ~/ps-aux-output.txtyou'll then find a file called ps-aux-output.txt in your home folder.
Can you upload its contents to a pastebin
and post a link back here.
Can you also post the output from:
gsettings get org.nemo.desktop show-desktop-icons
« Last Edit: July 01, 2017, 06:43:46 am by PCNetSpec »
« Reply #52 on: July 10, 2017, 12:37:29 pm »
Thank you Sir for your help. Although, After a lot of efforts I decided to reinstall my distro and it is now working as expected. :)
« Reply #53 on: July 10, 2017, 12:57:28 pm »
Great stuff :)
