Author Topic: Desktop is not showing anything.  (Read 6060 times)
Offline abhaymaniyar
Re: Desktop is not showing anything.
« Reply #15 on: June 20, 2017, 08:49:30 am »
If you open a terminal (Ctrl+Alt+T) and run:
nemo -n
do you now have a right-click context menu on the desktop ?
Is the desktop displaying the wallpaper ? .. and are you able to change the wallpaper ?
No not working and I am getting this output on running the command you said:
nemo -n
(nemo:10134): Gtk-WARNING **: Failed to register client: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.gnome.SessionManager was not provided by any .service files
Initializing nemo-dropbox 2015.10.28
Is it normal?
Online PCNetSpec
« Reply #16 on: June 20, 2017, 08:53:42 am »
Yeah ignore that gtk warning.
If you run:
gsettings set org.nemo.desktop show-desktop-icons true
nemo --quit
then restart nemo from the menu by opening a file manager (Files) instance.
Or by running:
nohup nemo -n &
and close the terminal with the X button top right
Do you now have a right-click context menu on the desktop ?
« Reply #17 on: June 20, 2017, 08:55:28 am »
If you run:
nemo --quit
Or by running:
nohup nemo -n &
Not working.
Online PCNetSpec
« Reply #18 on: June 20, 2017, 08:58:35 am »
Can you temporarily log off and log back onto the "Guest" account just to check if the desktop is working properly in that account ?
« Reply #19 on: June 20, 2017, 10:03:17 am »
No! Not working in "Guest" account also.
Online PCNetSpec
« Reply #20 on: June 20, 2017, 10:15:27 am »
Okay something is massively screwed up then
Maybe try reinstalling nemo
sudo apt-get install --reinstall nemo nemo-data gir1.2-nemo-3.0 libnemo-extension1 python-nemo
« Reply #21 on: June 20, 2017, 03:34:06 pm »
No sir! Not working.
Online PCNetSpec
« Reply #22 on: June 20, 2017, 06:02:10 pm »
You must have something else running then that's taking control of the desktop.
Can you run:
ps aux >> ~/ps-aux-output.txt
you'll then find a file called ps-aux-output.txt in your home folder.
Can you upload its contents to a pastebin
https://pastebin.com/
and post a link back here.
also has the desktop EVER worked or was it broken on install ?
« Reply #23 on: June 21, 2017, 07:11:06 am »
Here is the link you asked for:
https://pastebin.com/vGZB4h7E
I don't know if it was working on installation as the first thing that I did was restore the home folder from previous machine so I don't know about that exactly.
Online PCNetSpec
« Reply #24 on: June 21, 2017, 11:27:21 am »
Well I'm not seeing nemo running AT ALL
Open a terminal and run:
nemo -n
DO NOT CLOSE THAT TERMINAL.
Now with that terminal still open, if you right-click on the desktop do you get a context menu ?
« Reply #25 on: June 22, 2017, 06:51:09 am »
nemo -n
Still nothing. And when I am running "nemo -n" the command is doing nothing. Terminal just displays that "user@user" prompt instantly.
Online PCNetSpec
« Reply #26 on: June 22, 2017, 09:56:12 am »
nemo -n
won't return anything in the terminal
but after running it if you run:
ps aux | grep [n]emo
you should see something like
mark      1941  0.1  1.3 1537408 98072 ?       Sl   11:45   0:15 nemo -n
If you do, then nemo is running .. and **should** be controlling the desktop.
« Reply #27 on: June 22, 2017, 03:05:07 pm »
nemo -n
Yes I am getting similar output but still no response on desktop.
« Reply #28 on: June 23, 2017, 07:01:42 pm »
Hi abhaymanlyar, does right click work on anything, other o/s or whatever? Could this be a keyboard problem?
Online PCNetSpec
« Reply #29 on: June 24, 2017, 09:31:30 am »
Does hitting:-
Shift+F10
whilst on the desktop give you a right-click context menu ?
