Author Topic: Grub install failed  (Read 5676 times)
Re: Grub install failed
« Reply #15 on: June 08, 2017, 12:34:30 pm »
okay you seem to have 2 Linux partitions:-
/dev/sda8  569696256 953544703 383848448   183G Linux filesystem
/dev/sda10 334936064 569696255 234760192   112G Linux filesystem
do you know what these are ?
Offline jlanep30
« Reply #16 on: June 08, 2017, 12:43:00 pm »
Both were attempts to install Peppermint 8
« Reply #17 on: June 08, 2017, 02:09:18 pm »
Hi jlanep30, for future reference, could you please remember to encapsulate terminal outputs with the Insert, Code # function.  For extra long outputs, please use the Spoiler, Sp function.  If you’re a Chromium Browser and/or a Google Chrome user, please don't combine these functions.  For some reason they don’t work well together with these browsers.  Only use one or the other  ;).  These forum functions preserve the original format of the output.  This makes it easier for future visitors to relate to their own issues.  These functions are found in the forum editor, above the,  :-[ Embarrassed and  the :'( Cry emoticon respectively.  Use the Preview button to check how it'll look in the forum.  This time, I've done it for you - many thanks  ;).
Offline jlanep30
« Reply #18 on: June 08, 2017, 02:51:58 pm »
 Sorry about that!  I'm new to linux! I think I know what you are talking about and fixing to play around with it.
« Last Edit: June 08, 2017, 03:42:44 pm by AndyInMokum »
« Reply #19 on: June 08, 2017, 03:43:21 pm »
No problem, you're not expect to know everything right away  :).
« Reply #20 on: June 08, 2017, 04:12:42 pm »
Okay if they're both Peppermint, we can attempt to fix one of those, or we can remove them both and start again ?
I think we should do both .. see if we can fix one of those, and if it works delete them both and start again .. sound like a plan ?
If so .. Boot to the LiveUSB (and make sure you have an active internet connection) and run these commands in sequence:
sudo mount /dev/sda8 /mntthen
sudo mount /dev/sda1 /mnt/boot/efithen
for i in /dev /dev/pts /proc /sys /run; do sudo mount -B $i /mnt$i; donethen
sudo chroot /mntthen
grub-install /dev/sda --target=x86_64-efithen
update-grubthen hit Ctrl+D to exit the chroot environment. (the prompt should change back to $)
Close the terminal and shut down the PC
Remove the LiveUSB
Turn ON the PC
Were you offered both Peppermint or Windows ?
Offline jlanep30
« Reply #21 on: June 08, 2017, 05:37:03 pm »
If I boot live USB My wifi doesn't work and my computer doesn't have a Ethernet port...
Offline jlanep30
« Reply #22 on: June 08, 2017, 07:10:10 pm »
broadcom bcm43142 Network unclaimed:
« Reply #23 on: June 09, 2017, 05:57:02 am »
Okay try it without the internet connection .. and if you get any errors, please report them here.
Offline jlanep30
« Reply #24 on: June 09, 2017, 01:57:24 pm »
peppermint@peppermint ~ $ sudo mount /dev/sda8 /mnt
peppermint@peppermint ~ $ sudo mount /dev/sda1 /mnt/boot/efi
peppermint@peppermint ~ $ for i in /dev /dev/pts /proc /sys /run; do sudo mount -B $i /mnt$i; done
peppermint@peppermint ~ $ sudo chroot /mnt
root@peppermint / # grub-install /dev/sda --target=x86_64-efi
grub-install: error: /usr/lib/grub/x86_64-efi/modinfo.sh doesn't exist. Please specify --target or --directory.
root@peppermint / #
root@peppermint / # update-grub
Generating grub configuration file ...
Found linux image: /boot/vmlinuz-4.8.0-53-generic
Found initrd image: /boot/initrd.img-4.8.0-53-generic
Found Windows Boot Manager on /dev/sda1@/EFI/Microsoft/Boot/bootmgfw.efi
Found Peppermint 8 Eight (8) on /dev/sda10
Adding boot menu entry for EFI firmware configuration
done
root@peppermint / # exit
Offline jlanep30
« Reply #25 on: June 09, 2017, 02:02:11 pm »
Did not give me option to boot from peppermint.
« Reply #26 on: June 09, 2017, 02:22:30 pm »
Were there any errors during those commands ?
If not, have you checked to see if anything other than Windows is available in the U/EFI boot manager menu ?
(peppermint will be listed as <ubuntu> in the EFI boot manager menu)
From the LiveUSB, what is the output from:#
efibootmgr -vnow ?
« Last Edit: June 09, 2017, 02:30:16 pm by PCNetSpec »
« Reply #27 on: June 09, 2017, 04:01:44 pm »
Boot Mode is set to: UEFI with Legacy OPROM; Secure Boot: OFF
The other options I have is:
"Legacy Boot Mode, Secure Boot Off"
"UEFI Boot Mode, Secure Boot On"
Something tells me the boot mode could be the problem. I think one of the other modes might work properly.
Offline jlanep30
« Reply #28 on: June 09, 2017, 09:18:52 pm »
Ok I went through all the boot modes and still no change.
Offline jlanep30
« Reply #29 on: June 09, 2017, 09:34:22 pm »
peppermint@peppermint ~ $ efibootmgr -v
BootCurrent: 0003
Timeout: 0 seconds
BootOrder: 0002,2001,0000,0001,2002,2003
Boot0000* Hard Drive BBS(HD,,0x500)................-.C.......C.q...............................................A.........................
Boot0001* USB Storage Device BBS(HD,,0x500)............................................................................A...........................
Boot0002* Windows Boot Manager HD(1,GPT,bf8a8512-dbce-49fa-8e3f-333a1966b829,0x800,0xfa000)/File(\EFI\Microsoft\Boot\bootmgfw.efi)WINDOWS.........x...B.C.D.O.B.J.E.C.T.=.{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}...H................
Boot0003* USB1-1 (SanDisk Cruzer Glide) PciRoot(0x0)/Pci(0x1d,0x0)/USB(0,0)/USB(1,0)/HD(1,MBR,0x4294967288,0x800,0x773cd00)RC
Boot2001* EFI USB Device RC
Boot2002* EFI DVD/CDROM RC
Boot2003* EFI Network RC
