Author Topic: UEFI Bootloader failure: Peppermint on LAPTOP ACER ASPIRE ES1-533  (Read 1452 times)
Offline hellinux
Hi there,
I am new here and has never tried installing a Peppermint system  up to the point I bought the Acer Laptop in question for my wife hoping she could get started with such a promising (especially for newbies) Linux distribution.
Since I didn't find anything related to that Acer's bootloader issues here I went through the following instructions
https://askubuntu.com/questions/862946/unable-to-install-ubuntu-on-acer-aspire-es1-533
... first trying to reinstall the bootloader for Peppermint 7 and for last few days Peppermint 8  but with no success either.
The main observations in both cases were that the sudo apt-get install --reinstall grub-efi-amd64 returned the error below
/usr/sbin/grub-probe: error: failed to get canonical path of `aufs'
and the grubx64.efi was only under /boot/efi/EFI/ubuntu (not under /boot/efi/EFI/BOOT), as well as the grubx64.efi & bootx64.efi could only be found in upper case (/boot/efi/EFI/BOOT/BOOTX64.EFI &/boot/efi/EFI/BOOT/ubuntu/GRUBX64.EFI)
Is out there anybody else who tried the aforementioned workarounds, or something similar, and worked? Is there a Peppermint specific try that I have been missing somehow?
« Last Edit: June 05, 2017, 03:36:54 pm by hellinux »
Re: UEFI Bootloader failure: Peppermint on LAPTOP ACER ASPIRE ES1-533
« Reply #1 on: June 05, 2017, 05:25:06 pm »
Looks like you're attempting to reinstall the bootloader onto the LiveUSB/LiveCD.
Can you boot to the LiveUSB/LiveCD, open a terminal and post the output from:
sudo fdisk -l
Offline hellinux
« Reply #2 on: June 06, 2017, 04:14:31 am »
Perhaps it is so. After all, I installed Ubuntu 16.04 (my wife didn't want to wait for any longer  >:() but, since I have left an unused partition on the system, I am curious to look into the following two cases.
  • Take advantage of the bootloader as it is currently installed via Ubuntu process that I executed last night and try to install Peppermint 8 in the unused partition
  • Start it all over again and, when going through the workaround, detect the diffs between Ubuntu and Peppermint
The latter will drive my wife crazy, but anyway..  ::)
