Author Topic: Peppermint 8 released  (Read 12391 times)
« on: May 29, 2017, 05:24:28 am »
Hi there denizens of Peppermintland :)
Peppermint 8 is now out, so please go get it from the main website.
Here's an overview from Linux Quest to wet your appetite
The release announcement can  be seen here:
https://peppermintos.com/2017/05/peppermint-8-released/
The release notes are here:
https://peppermintos.com/release-notes/
And a MASSIVE thanks to those involved here:
https://peppermintos.com/2017/05/big-thank-peppermint-8-team/
« Last Edit: May 29, 2017, 05:30:52 am by PCNetSpec »
Offline DARKBOW923
  • All linux problem have solutions.
  • Peppermint version(s): Peppermint 7 64 bit :D
Re: Peppermint 8 released
« Reply #1 on: May 29, 2017, 08:25:35 am »
Haha loooool peppermint 8 released xD!
I need to try it now!  8) 8) 8)
I don't have any words (because my english is so bad and i commented in the principal page xD!!!!!!!) im going to make a live usb and try it when my download ends..
Possibly i make a review of this awsome distro (in spanish xD) Im so exited xDDDDDDDDDDDDDD
Regards
Now with new machine! Medion AKOYA intel core i3 7100 3mb caché 7th gen, 4GB RAM DDR4 Intel HD Graphics 630 1TB HDD space.
« Reply #2 on: May 29, 2017, 09:13:09 am »
Cheers DARKBOW923, we hope you like it :)
Offline DARKBOW923
« Reply #3 on: May 29, 2017, 12:16:57 pm »
Your team will be release pepppermint 8 respin? i make this question because i can't install or try peppermint 8  :'( :'(
Regards
Offline stratleray
« Reply #4 on: May 29, 2017, 12:27:59 pm »
Peppermint 8 is very nice. I like that the ctr+alt+t is working and also volume hotkeys was installed.
After installing my Brother printer, I got this message - lpr:command not found.
On P7 it worked out of the box. I had to install cups-bsd and it worked properly.
My fan is a lot more active on P8 compared to P7. The only thing I do not like.
« Reply #5 on: May 29, 2017, 03:29:11 pm »
Regards
Why can't you use Peppermint 8?  If you start a new thread, we'll investigate the problem  ;).
Offline HannahIsabelle
  • New Peppermint User
« Reply #6 on: May 29, 2017, 08:44:05 pm »
He's the reason I ended up switching from antergos to Peppermint, I love the customizations that I can do within XFCE :D I love the wisker menu and the blurred lockscreen so when I lock my desktop it still shows a blurred image of what I was working on
Peppermint 8 | Linux Newbie
Offline DARKBOW923
« Reply #7 on: May 29, 2017, 11:17:21 pm »
Regards
Thanks, but the problem is solved (my iso download was corrupted, i needed to re-download the iso and i installed yesterday peppermint 8)
I watch 'pluma' (in spanish) is 'editor de textos' (text editor) and the task manager is now more similar to the task manager of XFCE...
Regards.
« Reply #8 on: May 30, 2017, 12:16:21 am »
Regards
Regards.
That's fantastic  ;).  It's good to know everything is now working for you  ;).   Do you know the default text editor is now Xed?  We've also made life easy for people.  You can open Xed by typing either:
xed ~/<file.name>or
pluma ~/<file.name>and
gedit ~/<file.name>All of these commands will open files using Xed as the text editor  ;).
Offline drowzee1872
  • Peppermint version(s): Nine
« Reply #9 on: May 30, 2017, 01:17:03 am »
I am a big Peppermint fan, but i am not liking the new release. For me the first noticeable change is the fonts!  I preferred the font and size in 7, how do i revert back?
« Reply #10 on: May 30, 2017, 02:20:51 am »
That's nice and easy, navigate to:
menu > Favourites > Peppermint Settings Panel > Customize Look and Feel
From there you can select your desired font and size.  If you don't want full hinting, open the Font tab and change the hinting.   To change the, Title font and size, navigate to:
menu > Favourites > Peppermint Settings Panel > Peppermint Control Center
From there you can change the font and size.  We provided the tools to personalise Peppermint 8 to the way you'd like it.  I hope this helps - have fun  ;).
« Reply #11 on: May 30, 2017, 02:40:51 am »
Hi drowzee1872,
Running them side by side in Gnome Boxes - The only change I can see is in the Peppermint Control Center - change the Window Manager theme from "Numix" back to "Peppermint-Dark-7"
and as AndyinMokum stated - you can customise it to your liking :)
« Reply #12 on: May 30, 2017, 04:05:17 am »
Posted an article/link on LinkedIn.  Ikey always does that.   8)
I'll be curious to see the analytics  ...
« Reply #13 on: May 30, 2017, 05:03:52 am »
That's a good idea John  ;).
« Reply #14 on: May 30, 2017, 06:03:05 am »
The font and size hasn't changed, only the "hinting" .. so as Andy says, change it back to "Slight".
