Author Topic: Desktop "Computer" icon unknown file type[Solved]  (Read 2344 times)
Offline reme
  • Peppermint version(s): 7
« on: May 09, 2017, 04:37:32 pm »
I was messing around in the xdg-open file, trying to get magnet links to work in Chrome. I fixed that issue,  but in the process, created another. Since I changed it, when I try opening "Computer" from my desktop, I get an unknown application error, would I like to choose an application, etc. I'm pretty sure all I did was change this:
to this:
But changing it back only breaks magnet links, doesn't fix the Computer issue. Thanks.
« Last Edit: May 11, 2017, 05:10:42 pm by reme »
Re: Desktop "Computer" icon unknown file type
« Reply #1 on: May 09, 2017, 05:28:37 pm »
There's little point to a "Computer" icon on the desktop .. but if you really want one I have no idea why you're messing with xdg-open ???
You can easily add one from dconf-editor
Install dconf-editor
sudo apt-get install dconf-editorthen fire it up
the navigate to
org > nemo > desktop
and put a tick in "computer-icon-visible"
Offline reme
« Reply #2 on: May 09, 2017, 06:16:03 pm »
Maybe I didn't explain my issue clear enough, so I'll try again. I wasn't using xdg-open to try to add the computer icon to my desktop, it was already there, and functional before I edited xdg-open. I was only changing xdg-open to fix magnet links in Chrome. Using gconf editor was how I put the computer icon there in the first place. It just stopped working (giving unknown file type error) after editing xdg-open, and reverting my change didn't fix it. I tried turning it off and back on again in gconf editor, and that didn't fix it either. I know it isn't the most important issue, I just like having a shortcut to a place that shows all my drives in the main Nemo window.
« Reply #3 on: May 09, 2017, 06:21:22 pm »
So what did you do to xdg-open ?
and does running
nemo computer:///still work ?
Offline reme
« Reply #4 on: May 09, 2017, 06:27:09 pm »
Running "nemo computer:///" does work. I showed the change I made to xdg-open in the first post.
« Reply #5 on: May 09, 2017, 07:22:37 pm »
I'm kinda baffled why you'd need to edit xdg-open to get magnet links to work in the first place .. they should work just fine in Peppermint 7 as we've already tweaked xdg-open to work with chromium/chrome and magnet links ?
the only line you should need to change is line 916 (very close to the end)
So you're changing:-
    lxde)
    open_lxde "$url"
to:-
    lxde)
    open_gnome3 "$url"
Offline reme
« Reply #6 on: May 10, 2017, 06:25:16 am »
Magnet links worked fine with firefox and transmission, then I switched my browser to Chrome, and they still worked with Transmission, then I switched from Transmission to Tixati, and the first time I used one it worked, but the second time Chrome gave me a dialog box asking how I wanted to handle magnet links, and I clicked the wrong thing and they stopped working. I tried several solutions from googling around, and editing the xdg-open and switching
X-Generic)
           DE=generic
to
X-Generic)
           DE=xfce
did finally fix it, but then I encountered my current issue, which googling hasn't provided a solution to.
My line 916 in xdg-open already is
lxde)
    open_gnome3 "$url"
I searched and I don't have a line that shows
lxde)
    open_lxde "$url"
« Reply #7 on: May 10, 2017, 08:30:57 am »
Try this:
pluma ~/.local/share/applications/mimeapps.listadd this line at the bottom
x-scheme-handler/magnet=tixati.desktopmakes sure it doesn't contain any other line that starts with
x-scheme-handler/magnet=SAVE the file.
Now see if Chrome/Chromium opens magnet links.
But you should NOT need to edit xdg-open.
Offline reme
« Reply #8 on: May 11, 2017, 06:36:06 am »
I restored xdg-open from a backup, and used your instructions for fixing magnet links. Both Computer and magnet links are working now. Thanks!
« Reply #9 on: May 11, 2017, 08:06:48 am »
Great news, and you're welcome :)
If you're happy this is now (SOLVED), can you please remember to edit the FIRST posting in this topic and change:-
Subject: Desktop "Computer" icon unknown file type (SOLVED)
Thanks in advance :)
