Author Topic: Retro Chromium/Chrome browsers and "apt update && apt upgrade" [SOLVED]  (Read 2151 times)
Good morning and how is everyone today?  I'm one the lucky ones who are having fun and games with the new Chromium/Google-Chrome Aura versions.  In their present state, my computer becomes unusable.  I've found the best solution is to retrograde to earlier versions.  At the moment I'm only using Google-Chrome.  I just don't like the way Chromium handles Flash, or Pepperflash.  It is always a bit hit and miss.  I have installed Chromium Version 34.0.1847.137, as described in the following link: How to Retrograde to Non-Aura Chromium/Chrome browsers. This works really well until I perform an apt update && apt upgrade.  The nice Chrome version 34 is overwritten and the very unstable version 35 is reinstalled.  I've tried removing this version and manually deleting the Google-Chrome config folder and files before reinstalling version 34.  Is there anyway of allowing the non-aura version of Google-Chrome survive the upgrade process?  Many thanks  ;D
« Last Edit: June 27, 2014, 07:47:42 am by AndyInMokum »
Re: Retro Chromium/Chrome browsers and "apt update && apt upgrade"
« Reply #1 on: June 27, 2014, 06:14:56 am »
Yes it can be told not to upgrade, and I'll add this to the tutorial
Here's how...
Uninstall the new version, and install the non-Aura version (as described in the downgrade tutorial.
Then once you're sure you have the non-Aura version, run:
sudo echo "google-chrome-stable hold" | sudo dpkg --set-selections
to lock the package at the currently installed version
If you run an "apt upgrade" or an "apt dist-upgrade" it'll inform you that google-chrome-stable is being held back ;)
to unlock it (should you ever WANT to let it update):
sudo echo "google-chrome-stable install" | sudo dpkg --set-selections
That is outstanding, it worked a treat.  These are really useful commands.  They are safely bookmarked  ;).  I must learn more about how to use the pipe function.  I guess this would work with some substitution for the Chromium browser and any package that needs holding back.   Many thanks   ;).
« Last Edit: June 27, 2014, 07:48:42 am by AndyInMokum »
Yup, just replace google-chrome-stable with whatever packagename you want to lock to the current version .. as in
sudo echo "<packagename> hold" | sudo dpkg --set-selections
and to unlock
sudo echo "<packagename> install" | sudo dpkg --set-selections
« Last Edit: June 27, 2014, 09:21:18 am by PCNetSpec »
