Author Topic: transparent menus [SOLVED]  (Read 2142 times)
Offline siawacsh
« on: April 30, 2017, 05:38:28 pm »
Hello, I am finding menu (not whisker) such as when I click on a file menu, or browser menu the drop down is transparent and the information gets confused with the app that is in the background. I like the menus to be opaque so there is a clear differentiation. I have tried peppermint control center desktop effects to no avail.
Here is a screenshot of what I mean.
« Last Edit: May 02, 2017, 08:40:04 am by siawacsh »
Re: transparent menus
« Reply #1 on: April 30, 2017, 09:28:13 pm »
How the heck have you done that :-\ .. have you installed compiz ?
Is this theme specific ? .. what theme are you using ?
With all the other problems you seem to be having .. did you keep a home partition from another distro by any chance ?
Do you have all these problems if you log into a guest session ?
« Last Edit: April 30, 2017, 09:35:02 pm by PCNetSpec »
Offline siawacsh
« Reply #2 on: May 01, 2017, 09:56:02 am »
There has been minimal customization. I am using Peppermint-light-7 for theme.
I will add a guest account and see how the system behaves.
Siawacsh
« Reply #3 on: May 01, 2017, 10:22:33 am »
Hi Siawacsh,
Go into Peppermint Settings Panel and then into Peppermint Control Center and onto the Desktop Effects
Change Opacity of popup windows to Opague - its on a slider.
Offline siawacsh
Re: transparent menus [SOLVED]
« Reply #4 on: May 01, 2017, 10:29:38 am »
Thanks Zebeedee that worked.
Siawacsh
« Reply #5 on: May 01, 2017, 10:53:21 am »
Hi
Glad it is now resolved and thank you for marking the post SOLVED  :)
Offline siawacsh
« Reply #6 on: May 01, 2017, 12:41:40 pm »
You are most welcome as all the folk here who helped. :)
Siawacsh
