Author Topic: Configure a Fresh Peppermint Install and Maintenance Tips [ARCHIVE]  (Read 4546 times)
Offline cavy
  • Caveman
How to configure a fresh UEFI install, on a SSD and post maintenance tips
Most tips will work for Legacy installs and hard drives, don’t apply specific UEFI or SSD tasks I.e efibootmgr or fstrim, it will be invalid.
Update and Upgrade
sudo apt update && sudo apt upgrade -y
sudo apt dist-upgrade -y
reboot
Upon restart follow commands below
Check grub
sudo update-grub
Identifying if your Peppermint: has been installed in UEFI mode or Legacy mode
[ -d /sys/firmware/efi ] && echo "Installed in UEFI mode" || echo "Installed in Legacy mode"
It is an either or, answer. If dual booting, you will have to update your grub on both Linux disto’s, to ensure an accurate reading. Unsure about Micro$oft as I do not use it
Check current kernel
uname -a
uname -n
uname -o
uname -r
dpkg --list | grep linux-image
Version
cat /etc/*release
Check Memory Usage
sudo apt install htop
type "htop" to start
type "q" to exit
Other methods
free
free -m
Check partitions
df -a
df -h
df -k
df -l
df -m
df -P
df –help
Parted
sudo parted /dev/sda
type "print" shows current partition scheme
type “select /dev/sdb”
to show second disk (sdb) if applicable
type "q" to exit
Troubleshooting
dmesg | more
dmesg | grep Memory
dmesg | grep eth
dmesg -c (clears the buffer for next restart, fresh)
Purge old kernel always double-check and use with caution
Run dpkg --list | grep linux-image   lists all kernels installed. Currently the newest kernel is 4.4.0-75, keep this and at least one other, preferably two for emergency use
sudo apt remove --purge linux-image-4.4.0-66-generic linux-headers-4.4.0-66 linux-headers-4.4.0-66-generic
Modify the above code on all three entries. I.e remove 4.4.0-21 through to 4.4.0-70, leaving the 4.4.0-71, 4.4.0-72 and 4.4.0-75. Please note it is an ongoing process or use Byobu
Purge by byobu
sudo apt install byobu
sudo purge-old-kernels
Disk Integrity run following separate commands in order
lsblk
ls -l /dev/disk/by-id
sudo dd if=/dev/sda of=/dev/null count=1
sudo dd if=/dev/sdb of=/dev/null count=1 (if applicable)
sudo dd if=/dev/sdc of=/dev/null count=1
Hardware and System
sudo lshw | head
sudo lshw -short
sudo lshw -businfo
Specific class
sudo lshw -class address
sudo lshw -class bridge
sudo lshw -class bus
sudo lshw -class communication
sudo lshw -class disk
sudo lshw -class display
sudo lshw -class generic
sudo lshw -class input
sudo lshw -class memory
sudo lshw -class multimedia
sudo lshw -class network
sudo lshw -class power
sudo lshw -class printer
sudo lshw -class processor
sudo lshw -class storage
sudo lshw -class system
sudo lshw -class tape
sudo lshw -class volume
inxi codes
inxi -Fxz         posting on forums
inxi -c 5         snaphot
inxi -c 5 -b      basic info
inxi -p           harddrive partitions
inxi -r           repos
inxi -F           full info
inxi -AG          sound and graphics info
inxi -ni          network
efi grub Warning: The command rm -rf DELETES code permanently, use with caution
sudo su
enter password
cd /boot/efi/EFI
ls
output of grub entries: I.e ‘linux distro' or microsoft
rm -rf Microsoft or linux distro removes an obsolete entry
cd
type “exit” to exit root
efi boot order Warning: The command efibootmgr -b xxxx -B DELETES code permanently, use with caution
efibootmgr shows current default boot i.e should be '0000'
sudo efibootmgr basic info
sudo efibootmgr -v full info
sudo efibootmgr -V shows version
sudo efibootmgr -b xxxx -B replace x's with i.e '0003' to remove obsolete entry
Check whether the scheduler is set to deadline Warning: always double-check and proceed with caution
Essential for SSD
cat /sys/block/sda/queue/scheduler
The output should be: noop  [deadline] cfq
If deadline is not listed, edit following
gksu pluma /etc/default/grub
locate this line:
add elevator=deadline
GRUB_CMDLINE_LINUX_DEFAULT="elevator=deadline quiet splash"
Save file, update-grub and reboot
Disable the write action "access time stamp" Warning: always double-check and proceed with caution
Essential for SSD
gksu pluma /etc/fstab
Add "noatime" to /, /var and /home partitions: But not swap or the /boot/efi entries
UUID=f0ae2c59-83d2-42e7-81c4-2e870b6b255d /               ext4    noatime,errors=remount-ro 0       1
UUID=2468-A1A2  /boot/efi       vfat    umask=0077      0       1
UUID=f0ae2c59-83d2-42e7-81c4-2e870b6b255d /home           ext4    noatime,defaults        0       2
UUID=f0ae2c59-83d2-42e7-81c4-2e870b6b255d /var            ext4    noatime,defaults        0       2
UUID=f0ae2c59-83d2-42e7-81c4-2e870b6b255d none            swap    sw              0       0
Manual trim
For SSD only
allow to finish, initial trim is slow
sudo fstrim -v /
sudo fstrim -v /var (only if applicable)
sudo fstrim -v /home
Trim anacron check
cat /var/log/syslog
Change cron tasks from weekly to daily
sudo mv -v /etc/cron.weekly/fstrim /etc/cron.dailyUpdate-grub and reboot Allow up to two hours, (with computer working/idling) before checking, I find a manual fstrim -v / confirms anacron has worked
Reduce Swap (the swap and pressure values share the same file)
cat /proc/sys/vm/swappiness
normally set at '60', ideal for a server, not desktop
gksu pluma /etc/sysctl.conf
scroll to bottom of file and add
#Reduce the swap tendency
vm.swappiness=1
Reduce Cache Pressure
cat /proc/sys/vm/vfs_cache_pressure
normally set at 100
# Reduce Cache Pressure
vm.vfs_cache_pressure=50
Limit write actions of Google Chrome
Essential for SSD
Settings → Show advanced settings → Section Privacy → then remove the tick for: "Use a prediction service to load pages more quickly"
Daily cache runs @ 200Mb plus, too heavy, use Firefox as daily browser
Firefox tweaks
Settings → preferences → advanced → network
default set to 350, reset to 0 (zero)
Then
Type "about:config" in the url bar (main address bar left hand side), agree to be careful, click on blue button
Type "sessionstore" then double click on x3 below, turning true to false
browser.sessionstore.restore_on_demand
browser.sessionstore.resume_from_crash
services.sync.prefs.sync.browser.sessionstore.restore_on_demand
Restart Firefox
Then
Type "about:config"
double click on browser.urlbar.maxRichResults reset to 0 (zero)
Restart Firefox
Clean start if your browser has become populated or you want clean slate
mv -v ~/.mozilla ~/.mozillabackup
cp -v -r /etc/skel/.mozilla ~/.mozilla
Restore
rm -v -r ~/.mozilla
mv -v ~/.mozillabackup ~/.mozilla
Restart firefox
Clear thumbnail cache
rm -v -f ~/.cache/thumbnails/*/*.png ~/.thumbnails/*/*.png
Then
rm -v -f ~/.cache/thumbnails/*/*/*.png ~/.thumbnails/*/*/*.png
Then
open dconf-editor
click on org → gnome → desktop → thumbnail-cache
click on maximum-age and set it to 30 days
click once on maximum-size and set it to 50Mb
Clear Recent Files
cat /dev/null > .local/share/recently-used.xbel
Install Libre Office
sudo apt install libreoffice
English GB language defaults are missing
sudo apt install libreoffice-l10n-en-gb hyphen-en-gb libreoffice-help-en-gb libreoffice-lightproof-en hunspell-en-gb then check read out before typing “y”
Check Synaptic: search box → libreoffice: then slowly scroll down looking for any GB language options, tick to apply, also choose extra icons, I.e Oxygen, Tango etc. Then install all.
Final check: open Libre Office go to: Tools → Options → Language Settings → Language: to see if the “tick and abc” default symbol is NOW shown
Install apps
Synaptic
Or via terminal, add separately, checking suggested and recommended packages, before typing “y”
Tip install vokoscreen after you have install libdvd-pkg
How to remove an app
For example purposes only, enter the following:
sudo apt remove rhythmbox --purge && sudo apt autoremove
This removes the app and all its dependencies. So replace rhythmbox with the name of the app you want to remove
There are occasions when the app name is NOT recognised by apt, due to naming nuances, requiring a Synaptic software search, while you there, uninstall or note specific name used and go back to terminal
DVD playback
sudo apt install libdvd-pkg
sudo dpkg-reconfigure libdvd-pkg
Agree to licence
Ubuntu Restricted useful but can affect vokoscreen
sudo apt install ubuntu-restricted-extras
To agree to licence, you may have to use tab key to move cursor to the okay button.
Remove Guest Log in session
sudo sh -c 'printf "\nallow-guest=false\n" >/usr/share/lightdm/lightdm.conf.d/50-no-guest.conf'
Laptop tools
http://www.noobslab.com/2013/07/how-to-improve-laptop-power-management.html
http://www.noobslab.com/2015/04/save-fix-ubuntulinux-mint-doesnt.html
Check boot up time
systemd-analyze time
systemd-analyze critical-chain
Check file and filesystem
sudo apt autoclean && sudo apt autoremove
sudo dpkg --configure -a
sudo apt clean
uptime
ls -ld /var/log/installer
ls -ld /lost+found
Useful Sites
https://forum.peppermintos.com/
https://peppermintos.com/guide/
https://linuxjourney.com/
https://help.ubuntu.com/
https://www.debian.org/doc/
http://lubuntu.net/
https://wiki.lxde.org/en/Main_Page
http://www.noobslab.com/p/tutorials.html
http://www.unixmen.com/grsync-gadmin-rsync-graphical-front-end-applications-rsync-tool/
https://sites.google.com/site/easylinuxtipsproject/Home
http://linuxbsdos.com/
http://aptitude.alioth.debian.org/doc/en/
http://linuxbsdos.com/2016/06/15/how-to-keep-your-boot-efi-partition-clean-of-old-linux-bootloader-folders/
http://distrowatch.com/
https://debian-handbook.info/
« Last Edit: April 29, 2020, 02:27:58 pm by cavy »
Re: Configure a Fresh Peppermint Install and Maintenance Tips
« Reply #1 on: May 03, 2017, 05:11:41 pm »
Some useful stuff in there cavy .. TVM :)
Offline Nowinbob
« Reply #2 on: May 13, 2017, 07:06:18 pm »
No,cavey,I went cold turkey and have used nothing but Linux since June '16.(except for my Android phone)I have had a recurring issue regarding dual monitors.I think it may have to do with the fact that my second monitor is actually a TV(insignia 32 in)Ubuntu seems to be the only distro that will allow me to position the second monitor on the left side of the main monitor.Since the TV/second monitor is bolted to the wall,this is a problem.I have had this issue on two different computers so far.I'll see if the i7 tower does the same thing.
Offline cavy
  • Caveman
« Reply #3 on: May 13, 2017, 07:13:26 pm »
Wish you luck with project  8) Plus converting your brother re original post: https://forum.peppermintos.com/index.php/topic,5541.msg55552.html#msg55552
« Reply #4 on: May 13, 2017, 07:18:36 pm »
Have you tried 'LXRandR' ?
I run 3 monitors (configured as 4) and the positioning works great !
« Reply #5 on: May 13, 2017, 10:40:08 pm »
You can achieve this quite simply by menu > Peppermint Settings Panel the click Hardware Section and then Choose Display Settings.   Look carefully - in there you can tell the monitors where to sit relative to each other (ie left or right)
Then, if your panel is in the wrong place go to panel properties and tell it what Monitor to appear on.
https://forum.peppermintos.com/index.php/topic,3950.0.html This Topic has screen shots for what I am saying.
« Reply #6 on: May 14, 2017, 02:36:39 am »
If the above suggestions don't help, can you post the question as a new topic (with a descriptive title) in say the "Hardware" board so future searchers can more easily find it and benefit from any discovered solution .. TIA :)
