Author Topic: Increasing print contrast (SOLVED)  (Read 1935 times)
Offline Jono
  • Peppermint version(s): 4+5
« on: June 26, 2014, 08:55:31 pm »
I've been emailed some pencilled sketches that are too faint to read. What's the easiest way to increase the contrast for printing? I'm doing a CAD drawing in Draftsight and they only have to be legible, not pretty. LibreOffice I suspect could do it but I'd prefer something simpler, though I'll learn it if I must.
By the way, well done to the Peppermint crew. P5 installed easily and runs great.
« Last Edit: June 26, 2014, 09:20:19 pm by Jono »
Offline mac
Re: Increasing print contrast
« Reply #1 on: June 26, 2014, 09:00:57 pm »
If it's a common image file you can do that in Gimp using the Curves tool.
Reg. Linux User #432835
Offline Jono
« Reply #2 on: June 26, 2014, 09:18:31 pm »
Thanks I'd forgotten GIMP. I'll give it a go and call it solved-hopefully!
Offline mac
Re: Increasing print contrast (SOLVED)
« Reply #3 on: June 26, 2014, 09:27:50 pm »
No problem.  Hope it works for you.
