Author Topic: Windows bootloader (SOLVED)  (Read 1473 times)
« on: April 21, 2017, 04:39:36 pm »
Hi!
Peppermint is not really new to me, I had it running on my old Asus Eee PC 1001px for a while.
Bought a new Asus F540L today and, you know, first things first... remove Windows 10 and install peppermint 7 😎!
Question??
How do I know if Windows bootloader is still there? I don't want it! Want everything that has any connection with Windows removed.
Thanks!
« Last Edit: April 24, 2017, 03:05:36 am by pmppinho »
Re: Windows bootloader
« Reply #1 on: April 21, 2017, 04:47:00 pm »
Hi pmppinho, and welcome to the forum :)
If it's new I'm guessing it's a UEFI system ?
What's the output from:
efibootmgr -v
sudo ls /boot/efi/EFI
« Reply #2 on: April 21, 2017, 05:15:33 pm »
Thank you!
Here is the output
pedro@pedro-X540LA ~ $ efibootmgr -v
BootCurrent: 0002
Timeout: 2 seconds
BootOrder: 0002,0003
Boot0002* ubuntu    HD(1,GPT,86100ed6-a3de-44fd-9990-896148db2588,0x800,0x100000)/File(\EFI\UBUNTU\SHIMX64.EFI)
Boot0003* ubuntu    HD(1,GPT,86100ed6-a3de-44fd-9990-896148db2588,0x800,0x100000)/File(\EFI\UBUNTU\GRUBX64.EFI)..BO
pedro@pedro-X540LA ~ $ sudo ls /boot/efi/EFI
ubuntu
« Last Edit: April 21, 2017, 05:31:15 pm by AndyInMokum, Reason: Encapsulating output with [code]. »
« Reply #3 on: April 21, 2017, 06:23:12 pm »
Nope, no sign of a Windows EFI bootloader ;)
« Reply #4 on: April 22, 2017, 12:51:50 am »
Great! Thanks!
Just wanted to be on the safe side 😆!
By the way, everything went problem free and I removed Windows 10 and installed Peppermint 7 in about 30min.
If any one else is planning to do the same...
-Power up you new PC
-Disable Fast start and reboot
-Press F2 at boot and Disable Secure boot, Save and exit
Note: No options to boot from USB, don't worry.
-Shutdown
-Insert your USB while the PC is off
-Power up and enter BIOS/UEFI again using F2
-Now USB is there!! Select it, save and exit
-Wecome to Peppermint 7
-Install and enjoy.
As said, all of this took me about 30min. Smooooth!
Thank you guys for the great work! Excellent distro.
« Reply #5 on: April 22, 2017, 10:07:29 am »
Great post !
Welcome aboard, pmppinho  :)
« Reply #6 on: April 22, 2017, 12:16:59 pm »
Thanks VinDSL!
« Reply #7 on: April 22, 2017, 02:21:34 pm »
Don't get too comfy, Peppermint 8 is just around the corner :))
« Reply #8 on: April 22, 2017, 02:50:34 pm »
I won't !
Oh, wait ... are you replying to pmppinho or me ?    :)
« Reply #9 on: April 22, 2017, 03:59:57 pm »
Hi PCNetSpec!
Great! When will it be out?!
Still this year?
And I just did a lot of system configurations 😥!
« Reply #10 on: April 22, 2017, 04:37:54 pm »
If testing goes well without too many bugs discovered that need fixing, hopefully end of May / beginning of June .. but please be aware we don't set a static release date, it's ready ONLY when we consider it ready ;)
« Reply #11 on: April 23, 2017, 01:01:56 am »
That's great!
Looking forward to it.
I know you guys don't set static release date 🖒!
Would it possible to keep some stuff? Like for example, configurations of libreoffice.
« Reply #12 on: April 23, 2017, 01:02:49 am »
...After updating from 7 to 8 i mean...
Online murraymint
« Reply #13 on: April 23, 2017, 01:16:00 am »
Your config files should work, possibly the whole /home folder since the underlying Ubuntu base will be the same. Someone will confirm that or otherwise later on, I think :)
« Reply #14 on: April 23, 2017, 01:26:00 am »
Thanks murraymint!
Good to be part of such a nice forum 😊!
