Author Topic: Software Updater [SOLVED/Answered]  (Read 2072 times)
Offline ronj1950
  • Peppermint version(s): Peppermint 5/32 bit
« on: June 26, 2014, 08:03:58 am »
Hello All,
Observation/question on software updater within Peppermint 5.  On the 3rd tap for 'updates', and after authorization, the boxes for those 4 'trusty' sources become unclicked within a second after I click it and check mark appears.  All other functions of the updater appear to work.
I do have all the Peppermint software sources clicked in 1st tab, and all but 1st option [cdrom] clicked for other software in second tab.  Updates do happen if I run program manually .. have not really given it a chance to run automatically.  And in conclusion I did have the same observation in version 4 in the last few months before 5 came out.
My theory is it really does not matter since I have all active in the first 2 tabs.
Thank you.
Ron
« Last Edit: June 26, 2014, 08:10:15 am by ronj1950 »
rej
Offline kendall
  • Co-Founder
Re: Software Updater
« Reply #1 on: June 26, 2014, 08:06:52 am »
Yes, you should be fine if everything labeled "updates" in the second tab is checked.
Offline ronj1950
Re: Software Updater [SOLVED/Answered]
« Reply #2 on: June 26, 2014, 08:11:37 am »
Thank you for the rapid response Kendall.
Ironically, automatic update just happened!
« Last Edit: June 26, 2014, 08:13:33 am by ronj1950 »
rej
