Author Topic: Peppermint Installer Boot Menu will not enter any options  (Read 837 times)
Offline benvigllow
« on: March 30, 2017, 06:49:54 pm »
Hello there. First time Linux user here and I'm trying to install Peppermint 7 onto an old PC with an AMD Athlon 64 x2 4400+, 4GB of DDR2 at 800mHz, and a 1TB HDD. I put the ISO file I obtained from the website onto a USB flash drive, and booted my PC from it. It will get as far as the Peppermint installer boot menu. When I attempt to hit enter to try Peppermint OS live, the computer beeps and flickers, then goes back to this screen. The same thing happens if I try to just install Peppermint OS.
Re: Peppermint Installer Boot Menu will not enter any options
« Reply #1 on: March 31, 2017, 02:58:31 am »
Hi, try these instructions to see if it can boot using the nomodeset parameter:
https://forum.peppermintos.com/index.php/topic,1974.msg20631.html#msg20631
