Author Topic: Peppermint 5 won't install?  (Read 13496 times)
Offline Ernest
  • Peppermint version(s): Trying to boot P5
Re: Peppermint 5 won't install?
« Reply #30 on: July 10, 2014, 12:54:06 pm »
Just wondering if there's the possibility to reinstall Peppermint4 and thereafter update to P5?
Anyone with experience about it?
« Last Edit: July 10, 2014, 12:56:26 pm by Ernest »
Offline rjm65
« Reply #31 on: July 10, 2014, 01:25:50 pm »
In the past whenever I've see that from a LiveUSB stick, I've just given it a while and it's continued.
I have no idea why some machines decide they need to look in the CD/DVD drive for so long (?) .. another option is to disconnect the optical drive during installation, then reconnect it afterwards.
Another option would be to just boot from a live CD, and give the machine what it is looking for...   ;)
Robert
Peppermint 9 User
Gateway Solo 9300 Pro
IBM T40
« Reply #32 on: July 10, 2014, 01:29:51 pm »
Precisely .. I meant to mention that  :-[
Offline rjm65
« Reply #33 on: July 10, 2014, 01:41:17 pm »
In my experience with some older laptops, I found they just don't like booting from usb sticks for some odd reason, but a cd or dvd boots just fine....  ;)
Robert
Peppermint 9 User
IBM T40
Offline Ernest
« Reply #34 on: July 10, 2014, 03:56:18 pm »
PCNetSpec and rjm65 I guess your advices were destined to yarn, right?
Because I tried just the first attempt with a pen drive and thereafter only with a CD.
But at least in my case, I'm afraid, as long as this bug with firewire management exists, there won't be much left to do.
Offline yarn
  • Peppermint version(s): Peppermint 4
« Reply #35 on: July 11, 2014, 07:05:36 am »
After lots of trial and error, it froze on this.
[85.494233] sony_laptop:Sony Notebook Control Driver v0.6
[85.497539] input:Sony Vaio Keys as /devices/LNXSYSTEM:00/device:00/PNP0A08:00/device:13/SNY5001:00/input/input9
[85.497747] input:Sony Vaio Jogdial as /devices/LNXSYSTEM:00/device:00/PNP0A08:00/device:13/SNY5001:00/input/input10
I tried disabling sony_laptop but it kept reappearing.
The laptop's DVD drive won't read disks so I used a USB DVD drive.  :(
« Reply #36 on: July 11, 2014, 10:02:29 am »
So adding
sony-laptop.blacklist=yes
and/or
blacklist=sony-laptop
as a kernel boot parameter makes no difference ?
How about
acpi=off
? .. that's not ideal, I just want to know if it works.
Offline yarn
« Reply #37 on: July 12, 2014, 07:53:31 am »
When I tried adding only sony-laptop.blacklist=yes and blacklist=sony-laptop, it hanged here.
*Starting configure network device security                  [OK]
*Starting configure network device                  [OK]
When I tried only acpi=off
line 7: cant open /dev/sr0: No medium found
And when I tried using the first one and recovery nomodeset
sony_laptop: unknown parameter 'blacklist' ignored
« Reply #38 on: July 12, 2014, 08:02:11 am »
Try just
acpi=off
then when it gets to
leave it for about 20mins .. that line will probably repeat about 10 times .. then it may continue to boot.
If it does, don't install yet .. I just want to know if it does boot (eventually).
Offline yarn
« Reply #39 on: July 12, 2014, 09:17:48 am »
Try just
acpi=off
It did not boot. It  kept repeating until it gave up.   :(
« Reply #40 on: July 12, 2014, 10:00:48 am »
You know where you're adding the kernel boot parameters after hitting the "Tab" key ?
Somewhere in that white writing will be:-
file=/cdrom/preseed/peppermint.seed
that changing that part of the text to:-
live-media-path=/casper/
and appending ignore_uuid as a boot parameter
so the line also ends with:-
acpi=off  ignore_uuid
source:
http://askubuntu.com/questions/47076/usb-boot-problems
Offline yarn
« Reply #41 on: July 13, 2014, 06:44:01 am »
source:
I kept repeating line 7 still.
Offline yarn
« Reply #42 on: July 18, 2014, 03:27:50 am »
Is there anything I can do? :(
Offline yarn
« Reply #43 on: July 18, 2014, 04:01:59 am »
I read this and saw that he had to edit GRUB to fix his problem.
http://ubuntuforums.org/showthread.php?t=2214250
But how and what do I edit?
« Reply #44 on: July 20, 2014, 09:21:31 am »
So you want to try adding "acpi=off" as a kernel boot parameter ?
to the LiveCD/LiveUSB ?
Am I missing something here .. I thought we'd already tried acpi=off further up the page  :-\
« Last Edit: July 20, 2014, 09:23:59 am by PCNetSpec »
