Author Topic: Resetting the Peppermint 7 panel and whiskermenu to defaults  (Read 3826 times)
« on: March 16, 2017, 01:53:01 pm »
This tutorial will reset the bottom panel and whiskermenu back to defaults in Peppermint 7
(be aware - this will undo any panel/menu customisations you have made)
Open a terminal by hitting Ctrl+Alt+T
Now run these commands in sequence:
cd ~then
wget https://peppermintos.info/archive/reset-pm7-panel.tar.gzthen
tar xvf reset-pm7-panel.tar.gzthen
./reset-pm7-panel.shYou will be presented with the logout dialog .. CHOOSE LOGOUT  <-- It s VERY IMPORTANT that you choose "Logout"
Then log back on.
Panel and whiskermenu should now be back to defaults.
« Last Edit: March 16, 2017, 02:01:29 pm by PCNetSpec »
Offline cavy
  • Caveman
Re: Resetting the Peppermint 7 panel and whiskermenu to defaults
« Reply #1 on: March 16, 2017, 01:59:02 pm »
Is there an issue with either component ...I should be aware of...?   ???
Got mine as I like them.   :D
Offline Rodrigo
  • Peppermint version(s): 7
« Reply #2 on: March 25, 2017, 09:30:58 am »
 :) excelent!! Thank you very much
« Reply #3 on: March 25, 2017, 12:31:51 pm »
Nope, just think of it as a FAQ
« Reply #4 on: March 25, 2017, 12:32:50 pm »
You're most welcome :)
Offline ttooaatt
« Reply #5 on: April 11, 2017, 08:23:21 am »
Thank you for this tutorial. I was about to reinstall when I saw this.
« Reply #6 on: April 11, 2017, 08:33:28 am »
You're most welcome ttooaatt .. happy it saved you a job :)
Offline DARKBOW923
  • All linux problem have solutions.
  • Peppermint version(s): Peppermint 7 64 bit :D
« Reply #7 on: April 16, 2017, 04:44:10 pm »
Call me ignorarnt... but...
This tutorial is for 'reset' the  bottom or all wisker menu?
Bye!
Now with new machine! Medion AKOYA intel core i3 7100 3mb caché 7th gen, 4GB RAM DDR4 Intel HD Graphics 630 1TB HDD space.
« Reply #8 on: April 16, 2017, 05:09:20 pm »
It will reset the bottom panel and all panel plugins, INCLUDING the whiskermenu :)
