Author Topic: Problem Installing Peppermint 5 - SOLVED  (Read 1995 times)
Offline jlschwartz
  • Forum User
« on: June 25, 2014, 07:18:47 pm »
I just installed Peppermint 5 beside of Windows XP.  When I restarted I got this error:
error: symbol 'grub-term-highlight_color' not found.
grub rescue>
Please advise what I need to do to fix this problem.  Thanks.
Jeff S
« Last Edit: June 26, 2014, 11:20:42 am by jlschwartz »
Re: Problem Installing Peppermint 5
« Reply #1 on: June 26, 2014, 06:38:04 am »
OK, this may be something left over from a previous version of GRUB .. did you have a previous version of Linux installed next to Windows ?
Can you boot to the Peppermint LiveCD/LiveUSB, and post the output from:
sudo fdisk -l
Offline jlschwartz
  • Forum User
Re: Problem Installing Peppermint 5 - SOLVED
« Reply #2 on: June 26, 2014, 11:20:21 am »
After working on the problem for several hours last night, I have fixed the problem.  In the end, I booted to the Peppermint Live USB and downloaded boot-repair from Ubuntu.  I ran it and it fixed the problem automatically and everything works fine now.  That program is really awesome.  Thank you.  Jeff S.
« Last Edit: June 26, 2014, 11:22:25 am by jlschwartz »
Offline kendall
  • Co-Founder
« Reply #3 on: June 26, 2014, 11:53:58 am »
I'm glad you got it sorted and thanks for sharing what you did to resolve the issue.
Offline gabbott
« Reply #4 on: July 01, 2014, 02:09:45 pm »
Thanks for that. I installed peppermint 5 on a machine and had the same thing happen and that fixed it for me.
