Author Topic: Unetbootin not working for you (in Windows) ? .. try Rufus  (Read 3747 times)
« on: June 25, 2014, 12:44:21 pm »
If you're attempting to create a LiveUSB in Windows using Unetbootin, and it turns out to be unbootable .. just displaying the Syslinux version screen. and an flashing prompt...
First try typing
live
at the flashing prompt and hitting Enter
If that doesn't work.....
Someone on my other forum has informed me they have had better luck with Rufus:
http://rufus.akeo.ie/
Can't say I've tried it myself as it's a Windows tool .. but thought I'd mention it as an option.
As the Peppermint 5 ISO's are isohybrid images, Linux users can also use either the "dd" or "cat" commands to copy the ISO to a USB stick (but BE CAREFUL)
I'm also informed that Windows uses can use Win32 Disk Imager:
http://sourceforge.net/projects/win32diskimager/
to write isohybrid images to USB sticks.
Offline rjm65
Re: Unetbootin not working for you (in Windows) ? .. try Rufus
« Reply #1 on: June 25, 2014, 01:10:48 pm »
I use Universal-USB-Installer-1.9.5.1.exe from http://www.pendrivelinux.com on windows 7 and I never had a problem... Also another one to try that works and you can put as many distros on it as your usb chip can hold is Yumi... They create a boot menu in yumi and it lists each distro by number, and you can store as many as you like on your thumb drive...   ;)
http://www.pendrivelinux.com/yumi-multiboot-usb-creator/
« Last Edit: June 25, 2014, 01:12:44 pm by rjm65 »
Robert
Peppermint 9 User
Gateway Solo 9300 Pro
IBM T40
« Reply #2 on: June 25, 2014, 01:20:17 pm »
Cheers, but I thought Universal USB Creator specifically needed to have a distro "added" to its database (like LinuxLive), so wouldn't be ready for Peppermint 5 yet ?
Or maybe I'm wrong ?
Point is, different USB creators work for different people on different hardware .. so try them all :)
I only mentioned Rufus because I'd never heard of it before ;)
Offline rjm65
« Reply #3 on: June 25, 2014, 01:36:55 pm »
I have used Rufus on many occasions, it works just fine for making DOS USB boot drives, I use that when I need to boot a laptop that has linux only on it and they want the bios updated which can only be done using dos or windows....   ;)
Robert
Peppermint 9 User
IBM T40
Offline rjm65
« Reply #4 on: June 25, 2014, 01:39:14 pm »
Nope you are correct it uses a database, but you could also use the unlisted linux option, not sure if it will work though or not would have to try it and let you know....  :P
Robert
Peppermint 9 User
IBM T40
Offline rjm65
« Reply #5 on: June 25, 2014, 01:50:30 pm »
If you scroll to the bottom of the distro list and use the option to (Try and Unlisted Linux) and then point it to your peppermint 5 ISO it does work, I just booted my old IBM t30 using Plop boot manager Cdrom, and telling plop to load the usb stick, and peppermint 5 has loaded live to the desktop....   :)
Robert
Peppermint 9 User
IBM T40
