Author Topic: LightDM GTK+ Greeter reset possible?  (Read 1238 times)
Offline acer
« on: February 17, 2017, 05:28:22 pm »
System:    Host: HP-G60-Notebook Kernel: 4.4.0-62-generic x86_64 (64 bit)
Machine:   System: Hewlett-Packard product: HP G60 Notebook PC v: PCID
           Mobo: Hewlett-Packard model: 3617 v: 09.67
           Bios: Hewlett-Packard v: F.65 date: 12/15/2010
CPU:       Dual core Intel Core2 Duo T5800 (-MCP-) cache: 2048 KB
           clock speeds: max: 2000 MHz 1: 1600 MHz 2: 1200 MHz
Graphics:  Card: NVIDIA G98M [GeForce 9200M GS]
           Display Server: X.Org 1.18.4 drivers: nouveau (unloaded: fbdev,vesa)
           Resolution: 1366x768@60.11hz
           GLX Renderer: Gallium 0.4 on NV98 GLX Version: 3.0 Mesa 12.0.6
Audio:     Card Intel 82801I (ICH9 Family) HD Audio Controller
           Sound: Advanced Linux Sound Architecture v: k4.4.0-62-generic
Network:   Card-1: Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
           driver: r8169
           IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
           Card-2: Qualcomm Atheros AR242x / AR542x Wireless Network Adapter (PCI-Express)
           driver: ath5k
           IF: wlp3s0 state: down mac: <filter>
Drives:    HDD Total Size: 60.0GB (18.4% used)
           ID-1: /dev/sda model: Corsair_Force_LS size: 60.0GB
Partition: ID-1: / size: 51G used: 6.5G (14%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 4.26GB used: 0.00GB (0%) fs: swap dev: /dev/dm-0
Sensors:   System Temperatures: cpu: 40.0C mobo: 37.0C gpu: 43.0
Info:      Processes: 173 Uptime: 4:38 Memory: 662.3/3919.1MB
Still on Pre-Respin PM7 and is standing the test of time, kodi abuse and being used more than the inferior  BSOD Operating Systems I have..anyway that's another matter.
Over time my lightDM GTK+ greeter is intermittently showing the screen or just not bothering sometimes.  >:(
Another thing it does is, briefly show the greeter screen and then quickly go to the desktop screen before I have a chance to log in within seconds of start-up.
is this connected? If so, how can it be fixed? Is there a way to reset this, so it works all the time again?
Thanks in advance.
Offline acer
Re: LightDM GTK+ Greeter reset possible?
« Reply #1 on: February 21, 2017, 01:16:04 am »
A re-installation via synaptic cured it, for now anyway.
« Reply #2 on: February 21, 2017, 03:01:11 pm »
Great stuff, glad you sorted it :)
