Author Topic: Slow Boot...Hangs for long after selecting Peppermint at Grub Menu  (Read 3397 times)
Offline Capper33
  • Peppermint version(s): 7
Re: Slow Boot...Stays Hangs for long after selecting Peppermint at Grub Menu
« Reply #15 on: February 18, 2017, 09:04:25 am »
Offline Capper33
« Reply #16 on: February 18, 2017, 09:12:58 am »
I tried another usb port, but same problem. Not sure it can be the usb, because when I was booting peppermint from a live dvd, I had the same boot problem
Offline mac
Re: Slow Boot...Hangs for long after selecting Peppermint at Grub Menu
« Reply #17 on: February 18, 2017, 11:10:42 am »
Well, I'm stumped  :-\.  The only thing I know to suggest now is to wipe the external HD using gparted, repartition the drive and reinstall.   I would also start with a new .iso download.
Hold on a while, though ... somebody might have a better solution to offer.    ;)
cheers
mac
Reg. Linux User #432835
Offline Capper33
« Reply #18 on: February 18, 2017, 11:30:59 am »
Thanks in any case. I will hang on a while to see if there are any other suggestions. I actually doubt if a re-install and new iso will work. Given that it happens after a full hard drive install and with a live usb try. It even happens when I try linux mint from a live usb.
This stall happens before that Peppermint - starting screen comes...I do not know what happens in the background from the time I select to start peppermint from the Grub menu until the peppermint-starting screen comes. But it sure takes long, and the screen with the spider web-type or whatever, looks less defined as compared when I boot from my laptop - which makes me think it is graphics related.
Offline mac
« Reply #19 on: February 18, 2017, 11:38:02 am »
Can you trying installing to a USB flash drive using the USB Disk Formatter and USB Image Writer both of which are are located at menu > System Tools?
Offline Capper33
« Reply #20 on: February 18, 2017, 12:18:54 pm »
Ok I'll try tomorrow.
Thanks. Are there any special instructions for formatting?
Offline mac
« Reply #21 on: February 18, 2017, 01:00:03 pm »
Format the USB flash drive to fat32.  Very intuitive....just be sure to enter the correct USB drive and Image Writer will do the rest.    ;)
Offline ColonelPanic
    • Linux Linx 2016
« Reply #22 on: February 18, 2017, 01:46:42 pm »
Question:
 systemd-analyze blame says  "dev-sdb1.device"
hgm@hgm-MS-7529 ~ $ systemd-analyze blame | head -n 20
          15.701s apparmor.service
          12.741s dev-sdb1.device
           9.627s mintsystem.service
But blkid does not show any sdb1
hgm@hgm-MS-7529 ~ $ blkid
 /dev/sda1: UUID="f37412bc-a528-4fb0-a6e4-4751afe1302d" TYPE="ext4" PARTUUID="8352d179-01"
 /dev/sda5: UUID="1d0ac509-fc71-4d06-915f-7b9bb0fab0b2" TYPE="swap" PARTUUID="8352d179-05"
 hgm@hgm-MS-7529 ~ $
Is it possible that the delay is from your /etc/fstab trying to mount a partition that does not exist?
What is the result of:
cat /etc/fstab
AMD A8-3870 with Radeon HD Graphics 6550D, 8GB DDR3, Ralink RT2561/RT61 802.11g PCI
« Reply #23 on: February 18, 2017, 04:06:34 pm »
Maybe .. what's the contents of
pluma /etc/fstaband the output from
mount
