Author Topic: [SOLVED] How do I install a theme?  (Read 2801 times)
Offline Aero9000
« on: February 13, 2017, 09:50:34 am »
Reading this, I downloaded the Breeze theme, but the instructions on the Breeze download page don't work in Peppermint. So what is the proper procedure for installing themes?
« Last Edit: February 28, 2017, 04:17:31 am by Aero9000 »
Offline mac
Re: How do I install a theme?
« Reply #1 on: February 13, 2017, 10:34:11 am »
Download the Breeze theme HERE
Extract the .zip there in your Downloads folder
Open a terminal and run...
sudo mv ~/Downloads/gnome-breeze-master/Breeze-gtk /usr/share/themes
sudo mv ~/Downloads/gnome-breeze-master/Breeze-dark-gtk /usr/share/themes
then open Customize Look and Feel and select your new theme
then customize as per VinDsl's instructions
Reg. Linux User #432835
« Reply #2 on: February 13, 2017, 10:46:57 am »
Alternately, you can also create a folder in your /home folder called .themes and just unzip the theme there without elevated permissions, though there are a few limitations to that.  For one, only one user account (yours) will have access to the theme.  Though, if you only have one user account on your system, that won't be an issue.
Offline Aero9000
Re: [SOLVED] How do I install a theme?
« Reply #3 on: February 28, 2017, 04:19:14 am »
Marked as [SOLVED].
Actually I posted this topic in the hopes of resolving another issue, but to no avail
Please see new topic here: https://forum.peppermintos.com/index.php/topic,5175.0.html
